My scan, 12718 new?
24.8°W Alcomsat-1
Original von marval450
My scan, 12718 new?Here is my result
1.8m/rain -
in my san I an see :
12597V10000 continues singe qpsk 1/4
its is very strange to unlocked signal here in Algeria too -
12597V10000 QPSK 1/4 left
12603V20000 QPSK 1/4 continues singe updated by Dreamsat
12530V32723 ACM/VCM still there continues MIS2(0,254)
12519 H5000 QPSK 1/4 Not stable !!
12547 H20000 QPSK 1/4 BY Dreamsat 19.03.2019 very weak signal from here too
12605V20000 QPSK 1/4 left!
12706V3592 ACM/VCM 16APSK 8/9 New GS MIS1(0) -
OTHER CHANGING HERE !!!
12520H&12530H......SR 1000 -
NOW 12530H5000 ...
what are they trying to do ?
12530H2000 -
and nat. with other app SR and MOD with my equip only with this app:
TP must have another modulation and not with 0,9dB ,no other app find this. -
Original von clio
but everytime when iam started manually blindscan without started blindscan AUTO-mode
i have the true .a scan without SR ,wieso auch da strahl viel zu schwach,also ein BUG ,da nur diese soft/app diese nur SR ausgibt.melde diese auch nur das letzte mal ,da ich in diesem forum nicht für voll genommen werde.
hier ist mein allererster selbstaufgebauter SAT
noch vor DDR-Selbst-Auflösung. sogar mit 3D-Analog auf RTL/edit by qwer: screenshot + link.
Hello clio thank you for these report
tbs5990 can see only 12160H30000& 12240H30000 ..same thing as my tbs5521 ....these cards can see only "transport stream frequencies"
if you want to see signal of "genetic stream frequencies" like 12706V3592 ACM/VCM ,16APSK/32APSK ....etc .. you need a professional card like: tbs6903,tbs5927,tbs6983,tbs6925,tbs5925,tbs6908.....I don't know about tbsx-cards(tbs6909x,tbs6903x)?
but with a perfect spectrum using IQmonitor you can see clearly where there are these "genetic stream frequencies" even using non-professional card like tbs5990 or tbs5521 but unfortunately with out signal or symbol rate :53:
sorry for my bad English
regards
flie. -
there is no TBS5521 but i think you have this!
Multi standard
TBS5520SETBS5580TBS5590this pic is from your upload...
with standart you cant get this
/edit screenshots by qwer.
Original von clio
there is no TBS5521 but i think you have this!Multi standard
TBS5520SE
yes clioTBS5520SE=TBS5520Second Eddition=TBS5521
here an other scan with this card TBS5520SE belong to my friend "AlAmin66" from ALGERIA too
you can see that "genetic stream frequencies" like 12706V3592 or 12530 V32730 can't be locked with TBS5521 or others non- professional cards
hello stephan94
can you check vertical polarity (12706V3592 & 12530 V32730)? -
Original von flie
hello stephan94
can you check vertical polarity (12706V3592 & 12530 V32730)?Hallo flie
Ich habe gerade diese zwei Transponder versucht ,
mehr als schwach für mich .
Erstaunlich , dass trotz diese schwache Signal , die Parameter richtig sindDe mon lieu de réception ces deux fréquences sont plus que faibles , malgré tout les paramètres qui sont trouvés sont bon
From my place of reception these two frequencies are more than weak, in spite of all the parameters which are found are good
ps:the name of the satellite in the tables is wrong
stephan94
Original von stephan94
I don't know how you can get these good result even with LM=-8.1dB!
It is rare to see such results ! very impressive !
we can that feed-report is very important even for No locked transponders12530H5000 left and 12520H5000 is not stable (off now!)
12547H20000 signal now 5,6 dB... -
NEW !
12545H8000
12608V2546
12698V3248
12705V3592
GS SINGLE/edit by qwer: Uploader files disappeared (01.08.2020).
12515H1000 QPSK2 3/4 Continuous single...6 dB
12517H1000 QPSK2 1/4 Continuous single...11.5 dBto close from each other !
12545H8000
12515H1000
12517H1000
....All left!now I see :
12536H20000
12615H1500
12627H1000
12645H3000 -
12647 H 3000 Auto QPSK , GS
12627H1000 Left
12646H20000 SR Changed GS-single too.
