I am not sure if these signals are from Inmarsat or WGS-8 at 56.8E. There is only 0.5 degree between them from my location. There are 2 carriers, spaced at 1MHz, on 20201 and 20202MHz and a 32APSK signal, unlocked, on 20506 MHz, 32APSK, 9000, 3/4. The carriers are only 22dB C/N in 50Hz so are hard to find without an analyser. The APSK signal is well below threshold with me. All are circular polarised and were received on a linear feed.
I can not see the 20680 signal but the LNB has rolled off a long way by there.
Can anyone else get a better fix on them?
