10.25°E Echostar 21
  • 1 hour LHCP spectrum of Echostar 21at 10,25°E
    LO is 3650 MHz, so center frequency is 2195 MHz.
    The signal at 1434 is interference of strong local umts/lte carrier.
    Would be nice if someone could confirm.
    Hi Andre, have you also considered EchoStar 21, inclined at 10.25°E ?
    Because that satellite actually is known to have the 2170...2200 MHz mobile band.
    Probably our member s-band will know more!
  • Andre
    Hat den Titel des Themas von „11.8°E Sicral 1B“ zu „10.25°E Echostar 21“ geändert.
    I've never looked below 2200 as there is local cellular and the filters cut of at that frequency. Next time I have S on the dish, I'll check.
  • Yes. found the signals also from that direction.
    Btw where shall i look for Thuraya 2? Do you have a s-band frequency for me?
    _______________________________________
    L-Band 100 cm
    S-Band 370 cm, downconverter to 400 Mhz
    X-Band 180 cm, NORSAT LNB XT 1000 N
    Ku-Band 180 cm, Norsat Quad band LNB 1000 HU
    Ka-Band 180 cm, Norsat and Inverto LNB
    Receiver AR 5000 + NetSDR, SDRplay RSP2pro
    Here's my view of Echostar 21 on a 1.2m dish with RHCP feed. All signals appear to be time variant.
    Here' a waterfall of the transponder. It was at 18Ms/s but the Pluto can not run at that rate continuously so the plot was recorded in bursts. The FFT was 132k.
