This frequency should be from this satellite.
I see small peak on 21421 V too, no sign of signal,of course.
25.5°E Es'hail 1 [Eutelsat 25B]
Great catch, marval450!
I merged your post in this new GS>Ka toppic here.
Today I can´t test this signal, but of course, I will check it soon...
Best Regards
qwer. -
Hi marval450,
I can "see" the signal on 21612 V here too from position 25.5°E, but can´t lock it right now (1.2m).
Some db´s can be seen today.
Great thanks marval450!
Got 21612 V 19000 DVB-S2 today with lock (-dB) too (1.2m).
Only to give the my signal level from my QTH for 25.5°E in KA Band:
NOTHING, NADA, NIETE
Noticed that FEC is changing on fr. 21613V- 1/4 and 5/6.
Unlocked signal:
21612 V 27500 - probably GS/data...?
My Vertical scan using Norsat 9000LDF + 120CM Dish
[25.5E] 21613 Vertical 27494.084 2/3 DVB-S2 16APSK ACM
[25.5E] 21662 Vertical 41658.097 3/4 DVB-S2 QPSK-S2 ACM
My Horizontal scan
Most of them are not locked.
[25.5E] 21429 Horizontal 27494.11 8/9 DVB-S2 8PSK CCM
[25.5E] 21517 Horizontal 27494.202 8/9 DVB-S2 8PSK CCM
[25.5E] 21555 Horizontal 27494.06 3/4 DVB-S2 QPSK-S2 ACM (only when is locked)
[25.5E] 21594 Horizontal 27494.125 8/9 DVB-S2 8PSK CCM
[25.5E] 21632 Horizontal 27494.229 8/9 DVB-S2 8PSK CCM
[25.5E] 21670 Horizontal 27493.779 8/9 DVB-S2 8PSK CCM
More friendly parameter at this time, possible to lock:
21516 H 27500
/edit: deeper look here...
21429 H - no parameter found, looks like changed SR
21478 27500 with 0.3dB (probably 0.7dB under LM) >edit locked as GS now with up to 0.6dB
21516 H 27500 -> locked GS up to 0.6dB
21554 H 27500 - only via manual scan -1.5dB
21593 H 27500 with -0.4dB (probably 1.4dB under LM)
21631 H 27500 with -0.7dB (probably 1.7dB under LM)
21670 H 27500 with -0.6dB (probably 1.6dB under LM)
Now I can see parameter here - no fake:
21429 H 41660 (with -1.2dB via manual scan)
PS: probably 0.3dB more needed to lock 21593 H 27500...
Still these two unlocked remained at my place on 1.8m:
21429 H 41660 - just before lock...
21555 H 27500
...but other five are lockable.
Finally all 7 tp in linear horizontal spectrum are lockable here today afternoon 17.00 CET on sunny clear sky and colder temperatures than weeks before +14.0°C with 1.8m from my place.
21429 H 41660 - via manual scan
21478 H 27500
21516 H 27500
21555 H 27500
21593 H 27500
21631 H 27500
21670 H 27500
Finally I can see 21662 V 41658 here too... but about 0.4dB more needed to lock...
Other two from vertical spectrum are far away from lock.
my current scan
