06.0°E WGS-1 (relocated)
    Huge transponder but no 'regular' DVB modulation found
    Thanks hvdh for this missing position in our list
    20310 L in the center
    Relocated and then it confirm this thread, this is WGS-1
    I just realized this satellite is also KA Band C equiped and few frequencies are active.
    2 active TP
    20243 L 21300 2/3 (no lock from my QTH)
    20787 L 21300 2/3
    IP over DVB
    2 active TP
    20243 L 21300 2/3 (no lock from my WTH
    20787 L 21300 2/3
    IP over DVB
    My first experiences in band C on 1.2m dish, using a simple plastic plate. :126:
    Lockable here:
    20787 L 21300 2/3
    No sign of signal on 20243 L for me.
    Okay, now I can see 20243 L 21300 2/3 as unlocked here too...
    IP over DVB
    Locked 20243 L 21300 2/3 DVB-S2 QPSK today. :72:
    One more, but weak signal, unlocked:
    20610 L 21300 2/3 DVB-S2 QPSK
    Tried under constellation monitoring today. Nothimg new lockable.
    Also tried with IQmonitor, found (several times), but unlocked:
    20865 L 2766
    Just my current (here: linear) spectrum (20,5GHz-21,2GHz) with Inverto IDLK-SINL20-KAKU-OPP and modified CrazyScan Version 1.0.2.146.
    Todays circular left scan.
    PS: 21073 L 1972 (GS)
    20243 L is possible from my place today.
    Nothing else new.
    /edit: linear scan.
    20787 L 21300 2/3
    IP over DVB
    Changing SR now:
    20787 L 22035 3/4 DVB-S2 QPSK
    Just another try with Inverto IDLK-SINL20-KAKU-OPP and CrazyScan Version 1.0.2.146 on 1,8m (Invacom feed), using plastic plate inside.
  • No thing in my Area here too :88: !
    Lockable today:
    20610 L 22035 3/4 DVB-S2 QPSK
    Strange frequency range...? :25:
    "21289" L 1112
    ...to be confirmed...
  • I constantly receiving this signal using Inverto Twin Ka Circular Dual polarity.
    20502 L 22032.667 3/4 DVB-S2 QPSK
    PS: Ignore CS polarization.
    180 CM Jonsa
    TBS6983 - TBS6522
    Inverto Black Ultra
    Fuji LNB
    Norsat KA band 9000LC
    Norsat KA band 9000LDF
  • The only thing that irritates me a little is the "Inverto Twin Ka" LNB :25:
    I edited those 2 lines inside StreamReader.ini Some frequencies are working nice for me; up to 20642 MHz
    IFStart=250
    IFStop=2450
    180 CM Jonsa
    TBS6983 - TBS6522
    Inverto Black Ultra
    Fuji LNB
