47.5°W SES-14
    Some news for the list...
    3757 R 7200 3/4 DVB-S2 8PSK
    3988 R 7200 3/4 DVB-S2 8PSK, weak signal for me, encr.
    3991 L 8570 9/10 DVB-S2 8PSK, unlocked
    On again, but unlocked:
    3918 R 7200 3/4 DVB-S2 8PSK
    3937 L 8570 5/6 DVB-S2 8PSK
    3991 L 8570 9/10 DVB-S2 8PSK, unlocked ...
    Locked 3937 L now, it´s a GS stream.
    FYI: I re-moved all listed (as unlocked) "feeds" with SR 8570 now.
    Original von aspirepy
    Feed SES 14/47.5° W
    3817 L 7200
    DVBS2 8PSK FEC: 3/4
    MPEG4/4.2.0
    On again with changed content.
    On again:
    3757 R 7500 5/6 DVB-S2 8PSK
  • SES 14/47.5° W
    3871 R 9875
    DVBS2 8PSK FEC: 3/4
    MPEG4/4.2.0
    Id.: VICTORIA MAIN
    Mundial de Fútbol Sub-17-Brasil 2019
    Biss
    SES 14/47.5° W
    3883 R 9875
    DVBS2 8PSK FEC: 3/4
    MPEG4/4.2.0
    Id.: Brasilia MAIN
    Biss
  • Hi aspirepy,
    I want to congratulate you on your posts,especially as you are on the South American continent :76:,but being in another reception area,Paraguay,for us,Europeans,it almost doesn't matter what reception equipment you have.And yet,I have an amateur curiosity,what reception system do you have (antenna,lnb, tuner, etc.)?
    On the other hand,it probably doesn't matter,but I'd like to know if there's any intense activity in your area/forums like on our/European continent?
    Best regards :72:
  • Zitat
    Hi aspirepy,
    Best regards :72:
    Hello friend, first of all I thank you for your words, it is an honor for me !, really thank you very much!
    I will be happy to tell you what you asked me: I have a Freesky Triple X receiver, an cinebox optimo hd receiver and two PCI cards (TBS 6903X and 5520SE) although I use the latter 95%, because with my pc (it has more than ten years old) the 6903x card takes me more than 15 minutes to perform the scanner.
    I have an antenna of 2.40 meters of mesh that I move it manually (the engine has been decomposed for a long time, with two titanium lnb in "carona", the central one for the circular transmission satellites and the other for the linear transmission ones), in addition of four antennas of 90 cms. offset., two of them move them, when I look for the feeds in the 45 ° W Ku, in the 81 ° W Ku, in the 30 ° W Ku, etc.
    I apologize for not being able to answer before, I was with some familiar issues.
    I am at your pleasant orders and that of colleagues as little as I can.
    There are forums like this in Latin America, but as for the technical knowledge of everything that this Hobby implies, very little is known,
    With great appreciation, Esteban
    Pd .: I used the google translator, sorry if there is an error, I don't speak English.
    Hola amigo, antes que nada te agradezco tus palabras, es un honor para mí!, realmente muchas gracias!!.
    Con mucho gusto te comentaré lo que me preguntaste: tengo un receptor Freesky Triple X, un receptor cinebox oprtimo hd y dos tarjetas PCI (TBS 6903X y 5520SE) aunque utilizo en un 95% esta última, porque con mi pc (tiene mas de diez años de antiguedad) la tarjeta 6903x me toma más de 15 minutos realizar el escaner.
    Tengo una antena de 2.40 mts de malla que la muevo manualmente (el motor ya lleva un buen tiempo descompuesto, con dos lnb titanium en "carona", la central para los satélites de transmisión ciruclar y el otro para los de transmisión lineal), además de cuatro antenas de 90 cms. offset., dos de ellas las muevo, cuando busco los feeds en el 45° W Ku, en el 81° W Ku, en el 30° W Ku, etc.
    Te pido disculpas por no haberte podido responder antes, estuve con algunos temas familiares.
    Estoy a tus gratas órdenes y a la de los colegas en lo poco que pueda.
    Existen foros como este en latinoamerica, pero en cuanto a los conocimientos técnicos de todo lo que implica este Hobby, se sabe muy poco,
    Con gran aprecio, Esteban
    Pd.: usé el traductor de google, perdón si existe algún error, no hablo inglés.
    Yep, just on the same event ... :72:
