Using TBS6522 + 88CM Dish. It should be ME beam.
11177.233 - 3240 - Horizontal - DVB-S2/8PSK - 23/36 - ACM/VCM
11183.840 - 2865 - Horizontal - DVB-S2/8PSK - 25/36 - ACM/VCM
28.5°E Astra 2E
11131 H 8425 DVB-S2X/8PSK 25/36 ACM
11180 H 3240 DVB-S2X/8PSK 23/36 ACM
12575 H,24761,32/45,(S2X)32APSK,0.05,CCM-Packetized(new)
I can not lock 12546 H,24759,5/6 and 12634 H,24759,5/6. It can be in any mode and stream,packetized or generic.Most likely it's in generic stream!?!It must be checked by those who can lock them up.
Hallo satesco
Leider kann ich nicht preziser Ergenis als das bekommen
Unfortunately I can't get a more precise result than that
Hallo satesco
Thanks for trying.Most certainly both transponders have generic stream,without s2x extension.That shows both IQm screenshots of yours(!?).Please,try Crazyscan,too.Thanks.
Regards
Hier mit crazyscan ; Daten sind preziser mit IQmonitor
Here with crazyscan; Data are more precise with IQmonitor
It's important what you say,but the signal in your area seems to be stronger,that's why I wanted to check with Crazyscan if the two transponders have the S2x extension.
Thanks for checking
