Scan of the day.
New:
4065 H 5747 3/5 DVB-S2 8PSK "M6 Suisse", maybe a occasioanel GlobeCast feed - wait and see...
New "NO LOCKED":
4003 H and 4011 H
PS: 3854 V (in GS) changing SR and 3975 H, GS, new
Scan of the day.
New:
New "NO LOCKED":
4003 H and 4011 H
ZitatOriginal von qwer
New:
... more screenshots
New:
M6 Suisse - as regular channel - still there. Stronger signal in the evening.
prima, also die ersten Bilder und sehe ich ichtig, es wird linear gesendet?
Ja, Intelsat 10 sendet linear, genau wie vorher auf 68.5°E !
Danke Dir, H.
I don't know what is the current footprint of this satellite but it's very hard to lock from my QTH... (my 1st test)
The footprint looks the same for FR and DE, but Azerspace 46°E will be stronger in FR so maybe disturbing 47.5°E ?
http://exnetapps.intelsat.com/…t%2010%20at%2047.5%BA%20E
http://azercosmos.az/satellite-fleet/c-band/
Oh, boy, my signal is very bad if we have the same footprint !
The troubles are caused by Yamal 402, not Azerspace for my case.
I will test it with the 2nd 3.10m dish to confirm.
thanks hvdh.
Scan right now and 4065 H is down.
Last look after it was 17.25 today.
I confirm, bad signal with both 3.10m antenna, maybe the beam is not exactly as it's show,
usually I have nearly 4 dB less than Qwer (3m-> 5m) but for this position it's worse.
Feedsat, you meant Yamal 202 49°E, but that satellite is weaker in FR than in DE.
http://gascom.ru/en/infrastructure/space/yamal_202/
Anyway, it's bad to be squeezed between two neighbours, there is no escape by moving away from one a little!
I have a good recetption on Yamal 402 and Azerspace but when I look at the analyzer and fine tune adjust the azimuth for 47.5°E , I can't get more dB than this and I confirm Yamal is close to be locked when I'm on 47.5°E.
So true...
New "NO LOCKED":
4134 H 1718 DVB-S2
Looks like GS.
Can´t find any signal (in linear horizontal) this evening here...
Still nothing found in spectrum (linear horizontal).
Can anybody confirm?
Confirmed
Thanks Feedsat for checking!
So also very empty in vertical polarisation and only 4063 V is active.
Intelsat 10, originally at 68.5°, was at 47.5°E since January 2013, and started inclining in July 2015.
The satellite left 47.5°E on 3 March 2021, and is heading for 177.8°E.
