60.0°E Intelsat 33e
  • Zitat
    Original von superdish66
    Lower power, I think
    Very hard this one now from here (night time). Not possible to clear pictures.
    May anybody check, please?
    I can receive only 5 frequency with 2.4m.
    3737 R, 3751R, 3767R, 3772R, 4045R
    And yes, signal decrease after 9pm here.
    What about RTA 3725R, that has left right?
  • Zitat
    Original von chucky
    Thanks very much, chucky
    non chance ATM for 3785 R. It worked good early morning at 6.30 (10.7dB).
    Here is my current situation both Circular Polarization.
    3725 looks like off surely. I think it was in R, with reference my old BS in GS Toppic :72:
    Just a look on the lower band - no changes.
  • 3752R signal level reduced dramatically. No lock at my place with 175cm.
    Previously was very good.
    So only I can catch 3737R now (12.8 dB)
    August ´20 scan.
    Nothing changed since last scan superdish66.
    PS: 3902 R and 3920 L are GS, already listed.
    Just a look on content at this position - no changes.
    Just another scan here. No new TV or radio services appeared or left (all with same PIDs) - according my attached screenshots above.
    PS: 3860 L 2600 3/5 DVB-S2 16APSK - active feed, I think. Not new already reported here.
  • Just another scan here. No new TV or radio services appeared or left (all with same PIDs) - according my attached screenshots above.
    You Mean Signal OK in all Frequency but all Channel Here Stopped or left..!!
    To 103.0°E
    Yes, signal is unchanged and okay here - probably they use another spotbeam?
    Great stephan94 :76:
    Just my -unchanged- october ´21 scan.
    Just a look on content at this position:
    Akili Kidz now on 3785 R 5757 8/9 DVB-S2 8PSK (GBS left).
    Complete scan, click!
    Complete scan after 8 weeks - checked content - nothing new.
    Scan & just another look on the content her - but nothing changed, I think.
    satellitescommunity.de/index.php?attachment/82981/
  • Another scan - nothing new appeared - still very low signal on 3778 R 5720 3/4.
  • Not lockable at scan time (about 1.0dB under LM)... :90: ...3785 R 5757 8/9, Kenyan mux... no other changes.
    Still same bad situation here for 3785 R... 1.6dB under LM... :28:
  • Still same bad situation here for 3785 R... 1.6dB under LM... :28:
    :128:about 1.0dB under LM
