3527 R 1400 (got it on both polarization, maybe bad cross pol for this frequency...)
45.0°E Blagovest 1
44.9°E Galaxy 11 lower limit is 3700 MHz, linear.
45.1°E Intelsat 904 lower limit is 3625 MHz circular.More likely this comes from 45.0°E Blagovest 1 with still unknown C-band payload, but Russian satellites usually use lower part of C-band.
Less likely 44.0°E Thuraya-2 that also use lower C-band portion, but 5.2° inclination should be noticeable even in C-band?In Data>C topic for Galaxy 11, latest two catches are below 3700 MHz as well...
Original von hvdh
Surely not from Thuraya-2 (incl.), linear scans here from position 44.0°E and 45.0°E.
Nice find Feedsat.
My scan , LINEAR H+V .
Ok, Thanks, hvdh, according to our report, then, I think now it make sense to considere these frequencies on 45.0°E Blagovest 1.
Agree with Qwer, not Thuraya, it was inclined during my 1st scan and now the sat is alignAm I wrong ?
just for 3527 , don't know if Circular or linear, active on both
3612 in RHCP onlyMarval have checked in linear and got it also on both polarization
hvdh: OK Feedsat, I changed the topic name to 45.0°E Blagovest 1.
Am I wrong ?just for 3527 , don't know if Circular or linear, active on both
3612 in RHCP onlyHi Feedsat,
yes, in my linear scan yesterday, both frequencies appeared in vertical and horizontal (same as marval450 reported). Not tried in circular yet.
PS: So 3612 seems to be RHCP, according your results.
My linear scan.
3528 Circular scan, looks like I have good depolarization plate.
Original von marval450
3528 Circular scan, looks like I have good depolarization plate.Here we go, thanks marval450 for trying!
PS: Today it´s raing here and I will stay in the house. My C-band feed is totally off focus, as I know...I will change it asap.
One more test of 3527 R with 2m(less wimax intf.)
In L pol. -2,5db .
Scan of the day.
3528 R /L has left. -
3924 R 6400 constant QPSK2 2/3
hvdh: topic renamed to 45.1°E Intelsat 904
New:
3905 R 1000 3/4 QPSK2 CCM GS
Wide mux on 3700 L
NOt sure if Blagovset or IS904... (Linear scan)
3600 8000 -
3600 8000
This one I think is Circular Right.First picture Linear Left
Second picture Linear Right
Third picture Circular Right
Fourth picture Circular Left (with No Signal on that Freq.)Nothing else I found for this position by my side
Today's scan (if it's the correct satellite...)
Just my todays circular scan.
3934 R 3000
3878 & 3905 R are active -
Circular scan 3600 L (?) 2049
