IQmonitor tool
Without S2X the right top field is lighter, and no Signal Parameters.
(the 6903x is still running).
Ich habe genau das gleiche verlangt, nämlich mit dem TBS 5580 !!!
And post the result on the forum.
(Turn off 6903x - the card obviously does not support any DVB-S2 functions).
Interesting, the Omnicom is not special specified for S2X, but outputs the same values with the exception of the FEC.
I didn't describe it so incomprehensibly.
According to the specification, the 6903x goes up to FEC 32/45 (16APSK)
On the 6903x it looks like in the picture below with the S2X set
First, the main takeaway from this experiment:
If the transponder does not lock as a DVB-S2 signal, you need to check if it meets the DVB-S2X standard. To do this, just mark the DVB-S2X checkbox and just click the FeedReport button again
The corrected constellation clearly shows that the modulation corresponds to QPSK with a predominance of zeros in the stream. Definitely.
What 16APSK modulation are you talking about?
There are NO signs of this modulation on the constellation!
It is not clear what specification are we talking about?
From such a short and unrelated text, I did not understand anything about your problem.
Please provide materials that are saved on disk in the program database, and show a screenshot of the main program window with the Options page open
Right, there isn't 16 APSK.
Here from satesco 16APSk with crazyscan
I'll see now....
Hier mein Ergebnis mit diesen beiden Transponder.
Beide sind für Daten genutzt ,es ist höchswahrscheinlich ,
dass alles nicht mit den richtigen Normen ( für Radios oder TV) gesendet sind .
z.B. bei mir 11355 V bekommt ein voll ergebnis nur mit DVB-S2X Tasten ( 6983 ist nicht DVB-S2X tauglich)
ich glaube die TBS ( nicht nur ) -Karte sind von solche Übertragung überfordet ( sind auch nicht dafür gebaut)
Here is my result with these two transponders.
Both are used for data, it is highly likely that everything is not broadcast with the correct standards (for radio or TV).
E.g. with me 11355 V gets a full result only with DVB-S2X buttons (6983 is not DVB-S2X compatible)
I think the TBS (not only) cards are overwhelmed by this type of transmission (they are not built for it either)
Вот мой результат с этими двумя транспондерами.
Оба используются для передачи данных, весьма вероятно, что все транслируется не по правильным стандартам (для радио или телевидения).
Например, у меня 11355 V дает полный результат только с кнопками DVB-S2X (6983 не совместим с DVB-S2X)
Я думаю, что карты TBS (не только) подавлены этим типом передачи (они тоже не созданы для этого)
This is an old scan (see date).
It clearly shows that the modulation is pure QPSK, although StreamReader outputs 16APSK
I just performed this scan.
It clearly shows that the modulation is QPSK 3/4 by 97%, and 3% - 16APSK 3/4, although StreamReader produces 32APSK 8/9, which is not even close here.
So decide what to trust - calibrated I / Q constellation with modulation prediction or scale-free constellation and StreamReader's fantasies
ja das stimmt diesen TP auf 7°E kriege ich auch nicht rein egal mit welchem Equipment auch schon probiert.
A2
Eduard
26.11.201910722 V
DVB-S / QPSK
MPEG-227500 3/4 BBC im 126-2578 E7C
Western
45-53 dBW-R- BBC World Service Englisch Europa im 6662 Eng 13907 -R- BBC English Aus NZ im 6682 Eng 13909 -R- BBC World Service Englische Nachrichten im 6692 Eng 13910 -R- BBC World Service Arabisch im 6752 Ara 13916 -R- BBC World Service Afghanistan im 7022 Afg 13943 -R- BBC World Service Afrika im 7322 Eng 13973 -
wo kann ich die Informationsauswahlpunkte erstellen (von 0 bis 27 mit Niq = 2500)?
villeicht ist es bei ?
I/Q N 2500 x1
109 - I/Q N - zum Einstellen der Anzahl der Konstellationspunkte in einer Stichprobe (50 - 5500). Steigt mit zunehmender Präzision, aber auch Dauer
soll bei 2500 bleiben
110 - x - Fenster zum Einstellen der Anzahl der I/Q-Samples. Empfohlen für manuelle Suche 4 - 8
0 bis 27
Hätte ich so verstanden.
hier die Bilder 0-26
