Hi!
My Signal with 1,8m at Moment....
Regards, elchromo
Hi!
Regards, elchromo
21579 H 1100 2/3 8PSK added radios, Lome, Kara
TVT on 21580 is off now (yesterday I had reception...)
Equinoxe TV is now on 21569 H 1383. Transmission in HD. Will check tomorrow with TBS...
21540 seems to be off.
Scan with TBS and Equinoxe TV on new frequency. 21540 is off.
edit: Eden TV (21542) missing in the scan...it´s 13,3 dB
Just my scan with 1,2m. Bad situation on 21576 H.
Scan of the day (21534 H manuel scan).
Probably left: 21543 H 1100 3/4 DVB-S2 8PSK (TVC Benin)?
back from holidays, my scan. Also nothing on 21543 (TVC Benin).
Just a look on this position with 2,2m, using (wrong) Invacom ADF_10 feed and MCL-KP04 PLL LNB.
Lockable: 21575 H.
PS: 21534 H not in one scan.
21543 H (TVC Benin) seems to be back again.
Thank you Afreaka!
Can you post parameter (SR/FEC...VPid/APid)?
I want to update Ka list...
Here is my scan...
TVC Benin on 21544 (some LOF drift on my LNB, I think it´s 20249 right now) is still 8PSK 3/4 SR 1099, but there is always a problem with PMT: VLC via Crazyscan finds no PIDs. On my satreceiver VPID is 258 and APID 257.
Emirem seems to be off at the moment. Canal2-mux a little bit better now.
Thank you Afreaka!
Finally the spectrum has changed!
Some new programs added on 21600 and 21608 (thanks to elchromo from dxtv)
Still no signs from Emirem TV on 21536
21600 H 5206 2/3 8PSK
21607 H 7706 2/3 8PSK
21576 H, now with 5/6 ,no lock (115cm)
Lockable on 1,8m.
PS: Not perfect aligned LNB - only first test on new installed KATHREIN 1,8m PFA.
Just my current scan, using IQmonitor - no changes.
IQmonitor can find all frequencies in this range.
21541 H 1070 (weak signal here) and 21563.7 H 130 only in manual scan, using CrazyScan.
Just another scan on 1.8m and MCL-KP04.
Burkina Info TV probably left 21563 H?
Better signal today for Eden TV on 21541 H.
XMAS-scan with the 1.5m Gibby
Big signal for Vision 4, but Canal 2 is weak. Left: Burkina Info & STV. Radio easy to lock.
