New:
12593 H 6000 DVB/S2
85.2°E Intelsat 15
12508 H,10832,1/2,S2,ACM,Vpid-2048(enc),apid-8001-new GS(CNBC Globcast),
12597 H,14570,1/4,ACM-new GS -
11012 H,20000,3/4,32APSK,ACM-new symbol rate(also KooLy on FS)
11012 H,30000,3/4,16APSK,ACM,GS-new symbol rate,
11085 V,2000,3/4,32APSK,ACM,GS-new symbol rate(not new,on FS)
my signal Italy
New scan.
What do you catch and lock between 11700-12200 H on the Horizons-2, Russia? It's, as you know, at 85.2E. Thanks
Nem tudom, az 11092 H-t miért nem zárja be a TBS.
CryptoBox 800 UHD zárja.
Usually, a symbol rate of 34285 Ks is used on Data muxes, and to lock such a signal the card/USB TBS must be capable, even more so if the muxes have an S2X extension.
I'm not sure but you are using the USB 5927 tuner, and even if you can lock the signal, if the transponder is for Data, then your device doesn't memorize/save it.
Today scan this position
It surprises me that from the Russia spot, the signal in your area looks weak if I look at your spectrum. Shouldn't it be stronger just because you are right in the area of this beam?
Am I wrong?
Here's how the signal looks in my area from the two spots, Russia and the Middle East.
Am I wrong?
Yes. Intelsat15 stopped using Russia beam since 2022 year. Now V polarity in high band switched to Middle East beam, H polarity use West or East IOR beams.
If you're talking about my reception at 85.2E, the signal difference is due to the size of our antennas: mine is 1.50m, and yours is 1.80m.
As you know, every extra millimeter on the antenna counts. Sometimes, it makes a difference.
However, other physical or human factors are involved when we receive a signal. I won't mention them now.
11617 V,12378,8/9,16APSK-GS, new,
11635 V,4000,5/6,16APSK- GS, new,
11664 H,3662,1/2,S2-GS, new,
11691 H,19000,3/4,32APSK-GS, new,
12559 V,32660,5/6,32APSK-GS( N_Stanislav on spectrum-#93 )
12712 H,1250,1/4,s2-GS, new.
