you signal very bad
what you dish size?
you signal very bad
what you dish size?
Indeed, the signal is not very good with the 1.50m antenna, but I was lucky with the 6902se card to lock it.
Good for you.
You will find many such situations on the forum where small antennas beat big antennas, which may feed the vanity of some, but we should not jump to conclusions. The important thing is to be able to lock a signal that seems impossible with the equipment you have. And if you fail, others will complement you. If you want, that's the strength of a forum where everyone comes up with what they can.
There's a saying when I compare myself to others: I'm big, but when I look at myself, I'm small.
Have a nice evening.
if you any have profi lnb like smw or norsat pls feedback about signal on you side
its important ,becouse all near transponder(-+10-15 mhz tonight will be busy
and IBU lnb signal down to 8 or 8,5 db
Eutelsat 7A/7B/7C @ 7.0E
12681 Horizontal 16963
ID:L/Pool UHD Main
3840x2160 |41.810Mb/Sec |4:2:2 HEVC
...Alles anzeigen
ID:L/Pool UHD Main
Here comes everyone's turn. As Vico says:corsi et ricorsi. Unfortunately, this feed is encrypted.
yes
now signal strong
becouse near transponder not busy
after near transponder busy signal down
LNB IBU or another commercial lnb have not enought local stabilty if near transponder are busy,i think only profi lnb can do save strong signal
like transponder from yesterday 12550 H,17141,28/45,(S2X)/16APSK,0.05-UCL UHD2 M5, encrypted
morning 12-00 also strong signal
10992 V,22856,25/36,(S2X)/16aPSK,4K-E393 PATH1 UHD
11099 H,22856,25/36.(S2X)/16APSK,UHD-M2 Main VBR 4K,
Benfica v Olympique Marseille(UHD)
Liverpool v Atalanta
Hi Feedsat,
For some time, the Nodal FTV feed has been active at 7.0E. As the name suggests, it seems to be a station or hub for all kinds of broadcasts.
Is keeping this feed active a preparation for the Roland Garros tennis tournament, and if so, will this feed be used during the game?
PS_Maybe it is not unimportant, but I should mention that under Windows, this feed is tough to lock with 6909x, sometimes not at all, probably due to attenuation, but with neumoDVB under Linux, the feed is immediately detected and locked with the same card.
Last years, Rolland Garros was transmitted on Fiber (main) and ns3/4 mux (DRM) has backup and International broadcast.
Let’s see if it will be the same for this year
