Viel Glück .Sender wird wohl bis heute Abend da sein bis er dann abgeschaltet wird.
dvbsnoop V1.4.56 -- https://github.com/OpenVisionE2/dvbsnoop
Transponder PID-Scan...
PID found: 0 (0x0000) [SECTION: Program Association Table (PAT)]
PID found: 1 (0x0001) [unknown]
PID found: 2 (0x0002) [unknown]
PID found: 3 (0x0003) [unknown]
PID found: 4 (0x0004) [unknown]
PID found: 8 (0x0008) [unknown]
PID found: 9 (0x0009) [unknown]
PID found: 10 (0x000a) [unknown]
PID found: 14 (0x000e) [unknown]
PID found: 16 (0x0010) [unknown]
PID found: 17 (0x0011) [unknown]
PID found: 18 (0x0012) [unknown]
PID found: 19 (0x0013) [unknown]
PID found: 20 (0x0014) [unknown]
PID found: 22 (0x0016) [unknown]
PID found: 26 (0x001a) [unknown]
PID found: 28 (0x001c) [unknown]
PID found: 32 (0x0020) [unknown]
PID found: 33 (0x0021) [unknown]
PID found: 36 (0x0024) [unknown]
PID found: 256 (0x0100) [SECTION: Program Map Table (PMT)]
PID found: 512 (0x0200) [PS/PES: ITU-T Rec. H.262 | ISO/IEC 13818-2 or ISO/IEC 11172-2 video stream]
PID found: 768 (0x0300) [unknown]
PID found: 4112 (0x1010) [PS/PES: ISO/IEC 13818-3 or ISO/IEC 11172-3 audio stream]
PID found: 4113 (0x1011) [PS/PES: ISO/IEC 13818-3 or ISO/IEC 11172-3 audio stream]
PID found: 4114 (0x1012) [PS/PES: private_stream_1]
PID found: 8191 (0x1fff) [stuffing]
root@sf8008twin:~#
General
Complete name : D:\!FTA\20210916 1414 - 10983V SID 0x01 - instant record.ts
Format : MPEG-TS
File size : 74.5 MiB
Duration : 21 s 481 ms
Overall bit rate mode : Variable
Overall bit rate : 28.8 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : @L5.1@Main
Codec ID : 36
Duration : 21 s 500 ms
Bit rate : 24.3 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:2 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.059
Stream size : 62.2 MiB (83%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 21 s 480 ms
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Delay relative to video : -930 ms
Stream size : 1 007 KiB (1%)
Audio #2
Menu ID : 1 (0x1)
Format : MPEG Audio
Codec ID : 3
Bit rate : 384 kb/s
Audio #3
ID : 4114 (0x1012)-1
Menu ID : 1 (0x1)
Format : Dolby E
Mode : 20
Format settings, Endianness : Little
Muxing mode : SMPTE ST 302 / SMPTE ST 337
Codec ID : 6
Duration : 21 s 440 ms
Encoded bit rate : 2 304 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Frame rate : 25.000 FPS (1920 SPF)
Bit depth : 20 bits
Delay relative to video : -970 ms
Audio #4
ID : 4114 (0x1012)-2
Menu ID : 1 (0x1)
Format : Dolby E
Mode : 20
Codec ID : 6
Encoded bit rate : 0 b/s
Channel positions : Front: L R
Bit depth : 20 bits
