DVB-T / T2 Spectrum Analyser
  • Aufgrund der Reichweite der Sender besteht leider sehr wenig Interesse an DVB-T2.
    Es interessiert mich zwar auch, fürchte aber, dass du dich mit Crazyscan2 begnügen mußt.
    Due to the range of the broadcasters, there is unfortunately very little interest in DVB-T2.
    I'm also interested in it, but I'm afraid you'll have to make do with Crazyscan2.
    Vanwege het bereik van de zenders is er helaas weinig belangstelling voor DVB-T2.
    Ik ben er ook in geïnteresseerd, maar ik ben bang dat je het met Crazyscan2 moet doen.
  • Code
    Have a number of Dx-tv antennas here and set up. 1 adjusted so that I can change the polarization myself from H to V and back. Go stack a few antennas for more Db's (gain) and I'm all about the Dx.
  • CrazyScan - Browse Files at SourceForge.net
    for example: with TBS6281 and a small rod antenna, N 48,60 E 15,55
  • Here's how Crazyscan2(terrestrial) looks and works.
    You can download the app from here.
  • Better download the current versions
  • Check the analyzer path settings in CrazyScan2.ini
    e.g.
    Code
    [StreamAnalyzer]
    StartAnalyzer=3
    Proto=1
    IP=127.0.0.1
    Port=6969
    Buffer=96256
    Analyzer3=TransEdit
    Path3=C:/Program Files (x86)/DVBViewer/TransEdit.exe
    Params3=%proto%://%ip%:%port%
  • verify path 2 in laptop
    PS: some antivirus programs block the transmission
    Code
    Path2=C:/Program Files/VideoLAN/VLC/vlc.exe
  • @DeltaStar:
    which version of programms have you installed?
    If you use 32-bit programs
    the (path) entry is C:/Program Files (x86)/....
    with 64-bit
    the (path) entry is C:/Program Files/....
