Gold Master 525 Fantastic tool
  • HDTV and HEVC DVB-S/S2/S2X+T2/C receiver for TV, smartphones and PC + DVB2ip streamer + sat finder + DVB-T2 finder + s2 spectrum analyzer + remote diagnostics
    specifications:
    -DVB2IP Bridge op DVB2IP Bridge options:
    Open Web API...yes
    Watching DVB without TV set...yes
    Extension for Android Browser...yes
    Application....yes
    -RAMF options:
    Sat Finder.... yes
    Spectrum....yes
    DVB-T2 Finder....yes
    3G/4G Finder? under development
    3D RAMF LNB support....yes
    Reports with signal parameters.....yes
    Remote diagnostics (sending the report to the operator/installer) ....yes
    Fix-it-yourself instructions....yes
    - Measurements
    Spectrum.....yes
    RSSI.....yes
    SNR.....yes
    PER......yes
    LM.....yes
    Output voltage......yes
    Signal interference.. ...yes
    Antenna vibration.....yes
    Voltage in the cable.....yes
    22kHz control signal attenuate.....yes
    -SMDNet options:
    Streaming......yes
    Play content from the web link...yes
    Remote control using via HDMI ...under development
    One network for all devices..under development
    Playing all content in the network?.under development
    -Regular options:
    MPEG-4....yes
    HD....yes
    HEVC.. ....yes
    UHD....Using streaming
    DVB-S2X.......yes
    DVB-T2/C..........yes
    CA......yes
    Wi-Fi .......Embedded, MT7601
    Lan.......yes
    USB...1
    RS-232....On the motherboard
    HDMI......yes
    AV.....Jack
    s/pdif......yes
    ESD protection....yes
    Display.....yes
    Internal IR....yes
    External IR.....optional
    Chipset......Assembly 2230M3
  • it looks like a professional satellite finder and card satellite
    RECEIVER-ANALYSER-METER-FINDER (R.A.M.F.)
    its available for Android Phones , Tablet and PC at chrome extension
    antenna pointing option
    spectrum analyzer option
    also including SAT ID function like Dr HD 1000 and promax
    also including beep sound when got signals like other finders seems like Dr HD
  • Dear, Sathunter!
    I using two years this is device. The GM525HD excellent analyzer, and receiver, but the T2MI pocessign dont not work any owners, this is big problem.
    I have favorit feature in the devices, this the reporting tool.
    The device DVB-s tuner very sensitive, more sensitive with my TBS-6903 PCIe tuner card, but DVB-t its poor.
    You using this device, or only promote?
  • Dear, Sathunter!
    dear, SaTom
    I am using the device Its support T2-MI but I am not try with my self I will send you a video plz check
    Externer Inhalt youtu.be
    plz check and put experience here with T2-MI
  • Dear, Sathunter!
    I dont have HDMI capture device, dont know recording my video, but please testing to this funtion, with 9E, and 5W satellites. Dont works me.
    Thank you,
    SaTom
  • Dear, Sathunter!
    Thank you,
    SaTom
    Dear, SaTom
    I cant check this satellite on my location because is fringe beam but I will informed team to check that so wait my response for that thank you for query , if there any more feel free to discuss, have a nice day.
    Sat Hunter
  • Where is it possible to buy it ? Thanks
  • Hi, Coviello!
    This not question :-)
    I have many device, and also the GoldMaster SR-525 HD.
    The GoldMaster tuner more sensite as TBS6903, and/or GTMedia GT Combo.
    Anno i maked the device test (cca. two years old test):
    netboard.hu fórum
    netboard.hu fórum
    (This linked post i writed the Hungary language, please use google translater.)
    Best regards, and Happy New Year
    SaTom
  • Dear, all, dear DX amateurs!
    Maybe many you know, and use the Goldmaster SR 508 HD, and SR 525 HD devices.
    Now, the my IT developer friend programmed the new, freeware web API interface, to this devices.
    The new interface presentation showing in the linked post.
    netboard.hu fórum
    Please read it my article.
    This program freeware, but If i liking, and would help the developer, test it this prelease program.
    Send me to private message, we answer to you.
    Thank you!
    Best regards
    SaTom
    (Note: The article writed Hungaryan language, please use translater.)
  • SaTom ;
    I cannot help you with the Goldmaster.
    What caught my eye, though, is your diseqc command: (pl. DISEqC 8. port, EO1039F7)
    It looks like you used eo 10 39 f7 in the example, instead of e0 10 39 f7. So capital o, instead of zero.
    This is sometimes difficult to notice, as an error cause, so I thought I'd mention it.
    Greetz,
    A33
  • Hi, A33!
    Yes, you are a good observer, thanks!
    This web API beta a version, have many bugs, but interesting that worked this settings, i checking now again.
    Why dont testing, you not have this devices?
    Regards,
    SaTom
    Einmal editiert, zuletzt von SaTom (25. Februar 2024 um 15:35)
  • Now, i modoficated, corrected this settings, and tested. Not haven't chang the signal, or any parameters, worked normaly the measuring. Dont understand why not changed, or why work, if write O or 0?!
    So, therefore need many more test, please apply, and write private meassage, we asnwer to you! :-)
  • Dear all, dear DX amateurs!
    Please view this linked turtorial video, with showing how it work the new webAPI interface wich the GoldMaster SR508 and 525 HD new measuring, logger, and chart features are available.
    Externer Inhalt www.youtube.com
    This interface features in many funcion, but maybe the most importatn function, the signal-to-nois and LM chart.
    The chart timeline showing the measuring time highest and lowest signal data too. (example 24 hours measuring case)You knowing, the satellites signal value, not linear in the 24 hours time. Variable, example the satellites due to its " eliptical swaying". Therefore the two measured extreme signal value, also a one time window too, which is a good opportunity that sett prcision the dish. :)
    Best regards,
    SaTom
  • New version for R.A.M.F „SNR reports” tool!
    Again one week passed, added the newest functions, and more precisioned settings modes to reporting tool. :-)
    The new version 3.06.02
    (beta release)
    Change log:
    * new user interface
    (Corrected menu, vale, and parameter names)
    * new menu in to the Frequency parametering settings
    (Added the LNB Local Oscillator parametering box. Now, dont need calculating the IF frequency value, just selecting from the drop-down list the appropirate value.)
    * new "Polarization" input methode
    (Now you don't have to adding the int 0, or 1 parameter, only selecting the "Horizontal", or "Vertical" polarisation mode from the drop-down list)
    * new "Tone" input methode
    (Now you don't have to adding the int 0, or 1 parameter, only selecting the "On", or "Off" the 22kHz mode from the drop-down list)
    * new "DISEqC" input methode
    (Now you don't have to adding the HEX code parameter, only selecting the type 1.0, or 1.1 options switch port.)
    * new "3D converter polling" input methode
    (Now you don't have to adding the int 0, or 1 parameter, only selecting the "Enabled", or "Disabled " mode from the drop-down list)
    * new measurement "Time Limit / SNR Report" input methode
    (The time stepping modified second to minuts intervall)
    * new names to the Locking status indicator
    ("jel" modified to C/N name, and corrigated the update intervall for 20 seconds (one cycle request))
    We will soon make the webAPI application available and downloadable for everyone!
    Have a nice weekend!
    Greetings from the developer and SaTom! :-)
    (beta release)
    I understand that this is a promotion of the Gold Master 525, but I don't understand why the links to the new RAMF versions(3.06.02) are not posted.
    Maybe I don't know how to search, but I couldn't find the new version on GitHub. And if it is not hosted, where will it be found?
    If this device is still being promoted, it must be done „à la carte'.
    The Hungarian forum links are not updated with the latest versions of the R.A.M.F „SNR reports” tool and the new web API interface!
    I apologize if it is; I haven't seen them.
    Regards.
  • Dear Satesco!
    Thank you, that following the project!
    !!-Important-!!
    This project and promotions NOT OFFICIAL GoldMaster project, only my friend home made developing. The promotions dont have in the software download links, this is because, the software momently developer version.
    Of course, the software will soon be available to the public on the GitHub page with a download link, license, support, and of course also version tracking. :-)
    In the meantime, we ask for your understanding and patience!
    Thank You!
    SaTom
