![](https://www.satellitescommunity.de/images/avatars/bc/37-bc5d9e473d9b98c48ebb365b8efb53826ef4e160.jpg)
58.0°W Intelsat 21
CDM TV (4169 V) and Glitz Latinoamérica (3759 V) today on TBS 6522 (and PotPlayer)...
Personal spam...hey, 3759 V and 4159 V even on TBS 6903 today...
...but I can get some more today...
3975 H 4500 2/3 DVB-S2 8PSK, TVN National de Chile in clear...
4144 H 3750 3/4 DVB-S2 8PSK, Enlace
...and NHK World package on 4166 H always possibel, according freindly parameter.
PS: Disturbed spectrum scan.
... and this position has totally left for me now, according growing trees... even 4166 H is impossible
qwer it's a pity you don't have signal now
For me, this satellite is about 1.8* above the horizon
But the signals are very poor. I only partially receive larger packets, the rest depends on the weather.
Of course, Laminas 270cm antenna (Sweden)
I have several transporders that can be scanned. When the weather is good, all transporders are available, even the single ones.
By the way, a new channel has been added
"CARACOL TV HD"
tr.3893 H 8198
It turned out that the new package consisted of 4 channels
"CARACOL TV HD"
"CARACOL HD 2"
"CARACOL MOVIL"
"LA CALLE"
The Enlace package has been transferred to the new transporder
4144 H 3749
Just my current scan (for my personal stats)... about one month later on totaly "broken" spectrum
Alas, it is the effect of massive interference, hence destructive even beyond 3.2GHz with 4.9m(?) antennas.
This is the first time I've seen such a "dirty" spectrum.I never thought such a thing was possible.
Your large antenna could have attenuated some of the noise.
There's no escaping this effect. Possibly use the C band extension...
The problem at my location is a tall tree front in the residential area, which will make any reception on the extreme western C-band positions impossible. The next disappearing position will be 55.5°W...
Das Problem an meinem Standort ist eine hochwachsende Bäumefront im Wohngebiet, die jeglichen Empfang auf den äußerst westlichen C-Band Positionen unmöglich machen wird. Die nächste verschwindende Position wird 55.5°W sein...
qwer We are sorry and I understand your problems with the signal. If you write that the trees are blocking your reception from the 58w position. For me, this satellite is only 1.7* above the horizon, but it is also not very clear, there are often problems with reception even from a 2.7m antenna. Of course, the converter is installed next to the central converter.
I have the transporders below and several transporders available today
with high SR. but coded. -
I don't think the downward spikes on the spectrum are due to the tree obstructing the antenna but rather to the low elevation when the noise rises above the useful signal.
The tree only accentuates the weak signal and highlights these spikes.
You probably have interference at more positions on the arc, but that's because the signal picked up with your large antenna is stronger and doesn't show up on your analyzer.
I noticed this on my small antenna on both Ku and C bands : when the strong signal frequency shows up on the spectrum, the weak ones don't show up at all, or with less signal.
Of course, I could be wrong. I hope I'm not right.
