51.5°E Belintersat 1
    Original von marval450
    There is a problem to receive 11290 H with small dishes .
    On Turkmenalem 52,0E are active two feed TPs for Ashgabat 2017 5th Asian Indoor and Martial Arts Games, which will take place in Turkmenistan from 17–27 September 2017.
    I can confirm. :126:
    Only when I drive my dish more to the west (~0.5°), I can receive 11290 H.
  • very interesting,
    150 cm dish in position 52,5; I can receive all other 52 east tp, but not 11290 H 45000
    better I think may be the position 51,7 to receive this tp.
    1 Gib. 150
    1 T90
    1 Gib. 125
    Hi Kleinraisting,
    better you "drive" to the more west position, in my scan with 2.2m ~51.0°E was okay to lock 11290 H. :126:
  • all right
    thx
    Grüße
    1 Gib. 150
    1 T90
    1 Gib. 125
  • (blind) test per hands; its now o.k. with 12dB
    1 Gib. 150
    1 T90
    1 Gib. 125
    Okay, great!
  • 11290 H 45000, channels back on. :126:
    Two interferencing feed TPs from 52E should be off today ,maybe tomorrow.
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
  • New TP, 11230 H 45000 5/6 8PSK Pantelio
    One info card.
    Signal is much lower , than the rest of TPs. I think there is still the interference of the 52E´s uplink.
    11230 H 45000 5/6 8PSK, interference?
    My signal atm - probably lockable later... :91:
  • wie das?
    schielend an der 180er (46 in der Mitte) derzeit 7,5dB.
    Also müssten, zentral eingerichtet, gut 9dB da sein.
    1 Gib. 150
    1 T90
    1 Gib. 125
    Hallo Kleinraisting,
    hier ist die 11230 H weiterhin nicht zu locken mit 2.2m.
    Wie marval450 bereits fragte - möglicherweise kommt es hier zu Störungen durch den benachbarten Satelliten? :93:
    :125:
    Strange...
  • The 11230 H is lockable now, I checked sat. motion charts,BELINTERSAT is +0,03 , TURKMENALEM is -0,01 deg.
    TURKMENALEM is still transmitting 3 tps from BELINTERSAT.
    Original von pawelwa
    Lockable from my place today.
    11230 H 45000 5/6 DVB/S2 8PSK
    ...and today also possible after midday...
