Eutelsat 21A - 21.6E
11254MHz - Vertical - SR: 3332,371 Ks - 3/4 - DVB-S2 16APSK Pilot : ON -Coding Mode : ACM Bitrate : 9,929 Mbit/s Continous
Eutelsat W6 -
10981MHz - Vertical - SR: 1499,732 Ks - 2/3 - DVB-S2 QPSK2 Pilot : ON
Bitrate : 1,983 Mbit/s
Z.Z. Nicht aktiv
11306 H SR 27500
11428 H SR 36000
11305 H,27500,4/5,Dvb-S2/16APSK,ACM,GS,Multi
Vpid-256,Apid-257-WilloW HD Live
12660 H,1364,3/4,Dvb-S2/16APSK,ACM,GS,Single:new symbol rate
11168 V 1700
Also Big mux or various frequencies (NS3/4 ?) but no lock :
12660 V,682,5/6,Dvb-S2/16APSK,ACM,new GS,Single
There is one which I cannot lock:at 12655 V,965,4/5,16APSK,ACM,GS
12658 V,1083,1/2,Dvb-S2/QPSK,ACM,new GS,Single
OK, locked, Single
nice one Satesco
Hi Feedsat,
I knew that can be locked, but unfortunately I didn't manage with IBU although the signal is strong. What lnb Ku-band do you use?
Best regards
11323MHz - Vertical - SR: 29993,848 Ks - 5/6 - DVB-S2 8PSK Pilot : ON -Coding Mode : ACM Bitrate : 74,353 Mbit/s Continous Aktiv
anscheinend CNN
10845 V 24800 QPSK 1/4 only
12654 V,639,2/3,Dvb-S2/16APSK-Here's a new transponder with low symbol rate ,whose signal I could not lock.I am convinced that it is with stream Continous,for which I post here.
12654 V,682,3/4,Dvb-S2/16APSK-unlocked
What I wrote above is true now when it has been changed the symbol rate even though I have not locked the signal just like last time.
Thanks Satesco for the SR update, unfortunately 16APSK means strong signal but you can try EBS which is sometimes better for weak signal on low SR.
11295 V,613,1/3,Dvb-S2/QPSK,ACM,GS,Single-new symbol rate
12650 V,338,3/4,Dvb-S2/QPSK.ACM,Single-new GS
ZitatOriginal von Feedsat
10856 V 45000
hi Feedsat
pro or data ???
activ ???
Hi SATTEST,
10845 V has left and some others more (in low band).
And some new.
New:
11277 V 3333 DVB-S2
11280 V 1619 DVB-S2
11400 H 7038 DVB-S2
11672 H 1000 DVB-S2 (new SR)
"NO Locked": 11583 H 8000 DVB-S2
