IQmonitor tool
where is "DVBinspector" ?
Du kannst aus der 2407 die Datei "DVBinspector-1.10.0.jar" in das IQMonitor Pro Verzeichnis kopieren und ausführen (sofern java installiert ist).
Danach die vom IQMonitor Pro erstellte TS-Datei öffnen.
You can copy the "DVBinspector-1.10.0.jar" file from the 2407 into the IQMonitor Pro directory and run it (if java is installed).
Then open the TS file created by the IQMonitor Pro.
Vous pouvez copier le fichier "DVBinspector-1.10.0.jar" du 2407 dans le répertoire IQMonitor Pro et l'exécuter (si java est installé).
Ouvrez ensuite le fichier TS créé par l'IQMonitor Pro.
Alles anzeigen
Weak signal from your antenna is not the fault of IQmonitor Pro, it is your inability to tune an antenna of this size.
Congratulations on your undoubted success at a frequency of 4152 MHz H:
unlike the CrazyScan program, the IQmonitorPro program absolutely accurately determined the actual modulation of the VCM signal
I think that it will be useful to add "ACM or VCM" showing up in IQmonitor's feed-report
I did it but it doen't work ...probably deleted
deleting "DVBinspector" will be not good for IQmonitor "pro" version
and just be careful for this blind scan configuration!! ,it affect a lot in Blinscan results and also the results of Ultra-High resolution spectra !!!
another test @ 8°W
Also be careful in written the coordinates!! , it has be wrote with Comma and not with Dot !
It affect a lot in USUAL configuration in IQmonitor-pro ,unlike IQmnitr 2.4.07 it doesn't affect a lot
any way both programmes IQmonitor-pro and Crazyscan now use "Comma" in USUAL configuration (I use als DiSEqC switch with 04 ports )
for example ; use 22,8N-5,5E and not 22.8N-5.5E
I correct also my PARSER configuration no problem if you use "/" or "\";
[PARSER]
Java=C:/Program Files (x86)/Java/jre1.8.0_161/bin/javaw.exe
TSRLite=C:\Program Files\COOL.STF\TSReaderLite/TSReaderLite.exe
TSR=C:/Program Files/Cool.stf/TSReader/TSReader.exe
VLC=C:/Program Files/VideoLAN/Vlc/vlc.exe
MPC-BE=C:\Program Files\K-Lite Codec Pack\MPC-HC/mpc-hc.exe
4T2ContentAnalyser=C:/Program Files/ABC/4T2 Content Analyser/ABC4T2ContentAnalyser.exe
TrEdit=C:\ProgramData\CMUV\DVBViewer/TransEdit.exe
"GET PSI" works great in IQmnitr 2.4..07 but it is not working for me in IQmonitor pro version ???
Bonjour Flie ,
un peu de francais pour simplifier la compréhension
as tu regardé ma video ici ?
GET PSI fonctionne bien chez moi .
peut-être le chemin n'est-il pas correctement indiqué ??
dans le dossier IQmonitor PRo il y a bien le ts.TS ??
sinon je ne vois pas la raison , malheureusement.
Hello Flie,
did you watch my video?
GET PSI works well for me.
maybe the path is not correctly indicated ??
in the IQmonitor PRo folder there is indeed the ts.TS ??
otherwise I do not see the reason, unfortunately.
Hallo Flie,
hast du Dir mein video oben angeschaut?
GET PSI funktioniert bei mir problemlos.
vielleicht wird der Pfad nicht richtig angezeigt ??
im IQmonitor PRo Ordner gibt es ja die ts.TS ??
sonst weiss ich leider nicht woher es kommen kann .
Bonjour Flie ,
RE: IQmonitor tool
Oui je le vu maintenant , une trés bonne explication
https://workupload.com/start/v7U8QZzNcTR
il y'a toujour une fichier TS enregistré dans le dossier IQmonitor PRo .
mais "Get PSI" ne fonctionne plus pour moi dans IQmonitor pro
pas de probleme avec IQmonitor 2.4.0.7 !
Dankt der Möglichkeit von IQMonitor Pro mit "expand search band".
kann man mit einem ganz normal LNB ausserhalb von den üblichen
Frequenzbereich was suchen und was finden.
Thanks to the possibility of IQMonitor Pro with "expand search band".
you can with a completely normal LNB outside of the usual
Frequency range what to look for and what to find.
Mal abgesehen, dass meine Pro-Version über keinen Button verfügt, muss ich welche Daten ändern? und wo?
Apart from the fact that my Pro version does not have a button, which data do I have to change? and where?
Die Probleme mit GET PSI hatte ich ja gestern auch. Ich habe "get Lock" "Set Filters" und "Get PSI" nacheinander gedrückt und nicht.
Bei deiner Video-Version war ich erfolgreicher.
I also had the problems with GET PSI yesterday. I pressed "get Lock" "Set Filters" and "Get PSI" one after the other and didn't.
I was more successful with your video version.
flie:
I have installed the latest both versions (x64 and x86) of java (1.0.8.291), and copied the x86 version completly from directory 1.8.0.291 (c:\Program Files (x86)\Java\) in the directory 1.0.8.161.
You can download DVB-Inspektor from https://github.com/EricBerendsen/dvbinspector/releases, but use 1.14.0, the newest have an "ini Error".
Extract in any directory and click on DVBinspector-1.14.0.jar to start (maybe after a while twiced). I have tested and it works on two of my PC's
Servus femi ,
Ich dachte , dass in meinem Bericht es gut erklärt war , sogar mit screenshot
hier noch ein Bild davon , mehr kann ich nicht tun
Wenn Du aber kein "Button" hast
vielleicht ist deine Version nicht voll freigestaltet ??
das weiss ich nicht .
sonst ist es alles ganz einfach und geht ohne problem
viel Glück
Hi femi,
I thought my review explained it well, even with a screenshot
Here is another picture of it, that's all I can do
But if you don't have a "button"
maybe your version is not fully unlocked?
I do not know that .
otherwise everything is very easy and works without any problems
good luck
Der button "Expand search band" existiert nicht in meiner Pro Version.
Abgesehen davon arbeiten meine Gehirnzellen am Abend nicht mehr so gut wie noch vor einigen Jahren.
Ich will mit einem LNB
13750 - 14500 LOF 12800
um 400 bis 500 MHz runter kommen.
Ich nehm mir das expand.jpg zur Hand und probiere das morgen vormittag mit der 2407 hinzubekommen.
The button "Expand search band" does not exist in my Pro version.
Besides that, my brain cells don't work as well in the evening as they did a few years ago.
I want with an LNB
get down by 400 to 500 MHz.
I'll take the expand.jpg and try to get it done with the 2407 tomorrow morning.
Guten Morgen .
Bitte hier spricht man nur über IQmonitor Tool
An diese Meldung über 39° ost habe ich hier geantwortet
RE: 39.0°E Hellas Sat 3 <Europe>
Please only talk about IQmonitor Tool here
I replied to this message about 39 ° east here
vielen Dank und schönes Wochenende
2 erfolglose Versuche mit der 2407.
Mit einer LOF von 12800 geht es nicht unter 13750. Ändere ich die LOF kommen nur logischerweise nur Hausnummern raus.
2 unsuccessful attempts with the 2407.
With a LOF of 12800 it doesn't go below 13750. If I change the LOF, only house numbers come out logically.
Guten Morgen Femi,
Einen Tipp von Strannik
geht in Streamreader.ini und ändert die Zahl
wie auf dem Bild
IFStart 600
IFSport2500
Danach wird es normalerweise gehen
Good morning Femi,
A tip from Strannik
go to Streamreader.ini and change the number
like on the picture
IFStart 600
IFSport2500
After that it will normally work
Es ging mir nicht um TP zu finden ,sondern die Vorzüge mit IQ-M zu zeigen wo mein Problem mit Demodulator liegt, erst jetzt sehe ich das ich Demodulationsproblem mit meiner Satkarte habe im 32APSK Bereich. Dank IQ-M. Und Danke fürs feedback.
ZAZA:
Darf ich nach DVB-Karte, Antennengröße und eventuell deine verwendeten Einstellungen fragen?
Fiel dir das schon mit früheren IQ-Versionen auf oder war das nur zufällig im Laufe der IQ-Pro Tests?
Did you notice this with previous IQ versions or was it just by chance in the course of the IQ-Pro tests?
Schüsselgrösse 1.05Meter auf 39.0E
ich hatte des öfteren Pobleme mit 16APSK und 32APSK .
jetzt mit Diagramm von diesem Tool sehe ich das Problem mit TBS5990
werde demnächst wahrscheinlich eine andere Karte kaufen. Da diese von Anfang an Probleme bei hohen >HF macht.
