11482 V,2727,28/45,16APSK,0.05,ACM-Data(new),also GS-11482 V,2727,32/45,16APSK,0.05,ACM
![](https://www.satellitescommunity.de/images/avatars/10/4-108a9698659ce0541ae0bc31fa69f7eb9297d911.jpg)
57.0°E NSS-12 <ME/Europe>
My reception 0f 11483 V
12640 H,932,13/18,8PSK,ACM-Data(new S2X),
57.0E_Scanned upper band with tbs6590 and tbs6903X cards,using Crazyscan and IQmonitor.
- Offizieller Beitrag
Here are my results with TBS 6903X in horizontal high band:
12518 H 4661
12552 H 3501
12556 H 3501
12562 H 932
12568 H 9186
12614 H 1950 - probaby new?
12620 H 1950
12640 H 932
12660 H 3960 - not possible to lock...
I don't know if its new data or not .....
Has almost the same parameters ( different freq. ) with the previous admin's post
12664 H -
Thank you milan58!
Checkded with TBS 6522 - probably data, empty now...
12553 H 3502 13/18 DVB-S2X 16APSK
12557 H 3502 13/18 DVB-S2X 16APSK
12553 H and 12557 H have left.
An upper band update at 57.0E with Crazyscan and IQmonitor.
Merry Christmas
Of the S2X muxes on the upper-band spectrum (above), only a few are active in my area, such as:
12523 H, 6070, 1/4,
12644 H,3791,5/6,
12616 H,1949,(S2X)/16APSK,7/9,
12723 H,25713,16APSK-Data
With neumoDVB, 6903x, you can also find muxes hard to lock on Windows.
I'm not sure, but probably with the bigger antenna, I could lock all muxes on Windows. But it's good to try that you have access to this position. For now, they can all be locked in DVB-S2 as well.
Here's what this spectrum looks like on Windows and Linux:
12580 H,2850,32/45,(S2x)/16APSK-Data, new,
12583 H,2850,32/45,(S2X)/16aPSK-Data, new.
I tried to find more muxes in S2x on the upper band at 57.0E with the 6903x card under Windows 11. What Crazyscan found and locked can be seen on the spectrum. Considering that the signal is from the Middle East spot, I think it's a small success what I found.
But I used the same card on Linux with neumoDVB, and as you can see on the spectrum app, 6903x detected more muxes than on Windows. I would say that on Linux with neumoDVB, the 6903x card behaves and performs as well as the 6983 card on Windows.
I should also add that there are a few muxes that I could not lock although they are active.
Notice to those users with big antennas, with the recommendation to use a card with demod stid135.
12523 H, 6070, 1/4,
12644 H,3791,5/6,
...12722 H,23618,13/18,(S2X)/16APSK,Multi 1-Data, new symbol rate,
12523 H,6070,1/4 has left.
