Scan of the day (11,2-11,45GHz).
Still nothing on 11356 V right now.
As in many instances when we have strong signal and this time Crazyscan could not lock the signal at 70.5E. So it is pointless to struggle to lock the signal if the utility does not know how to identify it.
It is still unknown part of 6983 card even for Crazycat or Christian.
What I am saying now is valid only in so far as the vertical signal is transmitted to another system,such as for example,ABS-S system?It is also true that the signal on the vertical polarity is something weaker in our area than horizontal.Who knows.
As each of those who have posted on this topic,I also have strong signal at 11356 V,but I have the same result as well.
(It seems to me that Feedsat denouement me with his success at 11356 V!)
11356 V 44900 3/4 QPSK, new Mux
Jeevan TV
Jai Hind
Darshana
Sakhti TV
Janam
Kaumundy
Moon TV
Thanti TV
News 7 Tamil
Sathiyam TV
Signal with 1.40m antenna
11356 V,44890,3/4,Dvb-S2/QPSK
11555 V: 2 weak or not recognized modulation ?
11356 V, HEVC test in low resolution
Media One
12614 V 44993 8PSK 5/6
TS , too weak from my QTH and bad weather here (snowing).
which beam ?
which beam ?
No idea, I have here max. 5db on 2m.
I will try on.
Thanks Marval for checking this signal.
Feedsat-all different situation here today,
there is a pack of TV channels,without IDs.
Kazsport,NTK,CTV,Peretz,24KZ...
Thanks Marval,
8.4dB today but not enough for a 5/6 FEC on TBS
Can´t get a lock... maybe later.
Signal is stronger before noon, I did not get lock in the evening.
So if you can ,try now.
Thanks again marval450!
Got it in now locked...
That is great,qwer!
The beam is still a big mystery .
Reports from Tajikistan and India, receiving TPs
12690 V 30000
12726 V 30000
same channels as on 12616V.Must be different beam.
Interesting! I thought 12.5...12.75 would only be wide beam.
My Laminas can not see 70.5°E, therefore this Visiosat bisat, it's usually good enough for 11294 H and 11356 V.
12614 V gives only a few dB, will never be good enough with 8PSK 5/6.
This beam is really strange...with 120 cm Laminas in Slovenia the signal is on the edge but receivable. It is true that it is very cold at the moment (-7C).
Humaxboy
Wow, the signal is stronger (and it's raining here !), 8 channels in the mux. 12614 V 45000 5/6
Signal at my place (tree)
