- Offizieller Beitrag
7923.8MHz, LHCP, FHSS
This is only just visible here when it is above the trees. The signal I can see is a fast, frequency hopping. one covering about 6.5MHz. The bursts are about 5ms and quite narrow band although it is hard to see the actual bandwidth. The blue trace is the result of about 10 minutes of sweeps to catch the full extent of the hopping. The magenta trace is a single sweep. I could not see anything else on this satellite.
