05.0°W Eutelsat 5 West B
  • 11550 H,34284,2/3,16APSK,0.05,ACM,GS.It is also in S2X,but until I lock it,I post it here.
    11590 H has left the carrier,but was it moved to a slot in the upper band?
    12690 V,34284,1/4,S2,ACM,GS(new?)
  • 12605 V,34285,1/4,S2,ACM-new GS(I wouldn't be surprised to be in S2X).
  • 12711 H,34284,2/3,S2,ACM-new GS.Used tbs6590 card
  • Two for the list...
    11167 H 1703 - probably new
    11183 H 2140 - changed SR
  • thanks to hvdh for info here : :70:
    hvdh
    January 22, 2023 at 12:18 PM
    so this signal is from 5WB -Algeria beam
    3=11099,H,25000,35,2 ;8.3 (5.77) dB; 11:59 24/1/2023
    4=11167,H,1702,56,3 ;12.4 (0.49) dB; 11:59 24/1/2023
    5=11179,H,2719,56,1 ;11.5 (4.97) dB; 11:59 24/1/2023 ...........Data-TS
    6=11183,H,2139,23,3 ;11.7 (2.43) dB; 11:59 24/1/2023
    My equipment
    Ku: 1.80m OS
    C: 1.80m PF
    Ku: 1.21m @ 7°w
    C-Band LNB:Panorama ER861
    C-extended LNB: Bwei 5750Mhz
  • From the Algeria spot, I get some muxes, but only two I can lock. :3:
    11098 H,25000,3/5,8PSK-GS, locked,
    11166 H,2115,8/9,16APSK-GS,new symbol rate,
    11173 H,2134,2/3,16APSK-nolock,
    11182 H,2139,3/4,32APSK-nolock.
  • 11098 H,30000, 1/4, S2-GS, new symbol rate. Algeria spot.
  • 11169 H,45000,1/2,S2-GS, new.
