ZitatOriginal von marval450
First radio on air :TraceFM RDC.
Still no changes on 3826 R.
Probably new on Zambian package (3853 R): ITV.
3913 L 8667 5/6 AFP Africa (clear)
3725 & 3761 R 30000 3/4 copy of 4135 + 4171 R
PS: same as 47.5°W AFP is enc now (3913L)
Thank you Feedsat!
So on Kaonsat test LNB, I can´t lock these "old" TP now: 4135 R and 4171 R.
ZitatOriginal von qwer
... I can´t lock these "old" TP now: 4135 R and 4171 R.
Can somebody confirm this two as unlocked too?
PS: IQmonitor shows nothing on these two TP.
Hallo Qwer
Man kann auch mit IQmonitor fast sofort sehen wieviel dB für Lock fehlt oder nicht .
Bei mir fehlt sehr viel
aber beide Transponder sind da .
also für 4135 muss man 4,9+4,4 = 9,3 dB für's Lock
und für 4171 10.1dB
Du musst einfach auf die Frequenz doppeltklicken und nach ein paar sekunden kommt eine Konstellation und auch die daten bei dem Spectrum
viel Spass
stephan94
Danke stephan94, ich werde das dann beim nächsten mal testen.
They are both 8PSK 3/4...shouldn't they lock with 7.9 dB?
Yes, of course you´re right Afreaka.
Since transponder 3726 R and 3762 R appeared in lower band, transponder 4136 R and 4172 R shown with less 5.0dB signal as before (from my place).
PS: I tried with IQmonitor...
super Qwer
Jetzt kannst Du lesen was fehlt
schönen Abend
stephan94
Here it's OK, no change, no need 9.3 dB to lock a 3/4 8PSK
(wineguard/Norsat3220)
Thank you Feedsat for your feedback!
Now I know, I had to change LNB/polarizer to check these two TP.
OK so for the first time ever I tried C-band on an offset dish (prodelin 2.4m) but I'm disappointed with the result. I can't get a better SNR that I'm getting with a 1.8m PF dish.
I wanted to get the new Startimes muxes but no matter what I did in terms of adjusting the LNB position, I can't get over 7.1 dB on 3725R. In Ku band, this dish performs well, I get at least 2.5 dB more compared to the 1.8m PF, so why can't I get the same 2.5dB more in C-band?
So I wanted to ask if someone has an experience with C-band on offset dishes, if it's normal for it to perform not as good as a PF. Or could it be the fact I installed the dish upside down? Or is the scalar ring from ebay crap?
Here's my scan of 8W from today. Note - the polarization is swapped! Also attached a picture of how the LNB is installed.
all Startimes packeages fully enc
excepted Bundesliga id & test 2
3725 a 4171 R
3725 a 4171 R
Today 3725 R complete in clear (can´t test 4175 R with Kaonsat LNB ).
Today full package encrypted again (3725 R and 4171 R) - excepted Bundesliga, test 2 & ST Guide.
PS: First polarizer test with Kaonsat LNB for receiving 4171 R (nothing else changed in antenna setting)...
3860 R 1600 3/4 DVBS RTS SNG is off, probably feed
3889 R 30000 1/2 is off, RFI pack is now on 3964 R 4167 1/2 DVB-S2/QPSK
/edit by qwer: Merged 3860 R report in Feeds>C.
3826 R 13833 4/5 DVB-S2/QPSK
Added SBS TV.
New:
3895 L 2540 5/6 QPSK2 TVE Int.Africa + 2 radios
3925 R RTR Planeta is FTA
