Neue StreamReaderEX-BDA
  • Hallo
    neue StreamreaderEx_BDA 1.2.3.1305
    Feste Definition von PLP-ID für den Si2168 (Geniatech T230 / pt360)
    Volle Unterstützung für TBS 6903 (STV6120 / STV0910ADB).
    Please ask stephan94 again.
    stephan94
  • New StreamReaderExEx-BDA 1.2.4.1404 (test)_13.12.2016
  • new StreamReaderExEx-BDA- v.1.2.4.1406 from 04.01.2017
    StreamReaderEx-BDA 1.2.4.32
    Fixed TBS 6903/5/8 support (DVB-S detection)
    Added TBS 6528, 6590, 5520SE support
    https://sourceforge.net/projects/crazyscan/files/
    Thanks, Crazycat
  • StreamReaderExEx-BDA_new vers: 1.2.4.36 Date:28.07.2017
  • StreamReaderExEx-BDA_new vers: 1.2.4.40 released in 24.10.2017
  • StreamReaderEx-BDA 1.2.4.45
    Fixed freq offset correction for all supported terrestrial/cable devices
    Hauppauge WinTV-soloHD & dualHD DVB support
    StreamReaderEx-BDA 1.2.4.52
    Fixed TBS 5580 support in terrestrial/cable mode.
    Fixed DVB-C lock for Silabs based devices.
  • StreamReaderExEx-BDA_ v.1.2.4.60
    -an improvement to the blindscan for tbs6903
    A warm thanks to crazycat :)
    This version doesn't work good for me, first attempt crazyscan got stopped while blind scanning(10+ min nothing), second attempt other range it missed a tp.
    TBS 6903, Openbox SX6, Supral 1.2m, Lans 90 (gone), motor Barton 380 MG, lnb Inverto
  • I have to admit I did not check this patch,but probably the manufacturer has to improve the driver so the patch has the desired effect.
    And as we know by now, crazycat has a way to work the singular without the need of a team to help him.That makes him great from all the developers of the programs.In other words,he is a step or two in front of others in this branch...
    What is new?
    180 CM Jonsa
    TBS6983 - TBS6522
    Inverto Black Ultra
    Fuji LNB
    Inverto KaKu
    NJR2825 (KA BAND B)
    Norsat KA band 9000LC
    Norsat KA band 9000LDF
    Several C-Band LNBs
  • stream-reader 1.2.4.78 (23-03-2019) :73:
    Sorry I don't know what news in it ?
    Files
    My equipment
    Ku: 1.80m OS
    C: 1.80m PF
    Ku: 1.21m @ 7°w
    C-Band LNB:Panorama ER861
    C-extended LNB: Bwei 5750Mhz
  • update streamreader to latest test build
    http://crazycat69.narod.ru/sattelite/Stre…derExEx-BDA.rar
    thank you Crazycat :71:
    Now 1.2.4.79 (05-04-2019) :68:
    My equipment
    Ku: 1.80m OS
    C: 1.80m PF
    Ku: 1.21m @ 7°w
  • Thanks flie:72:
    StreamReaderEx-v.1.2.4.79
    new:* Speed-up STiD135 init and fft scan.
    tbs6903X-another low symbol rate locked at 90.0E:
    12556 H,281,1/2,S2-Data
    Please ask flie again.
    thank you Crazycat
    NEW 1.2.4.82 (08-06-2019) :73:
    My equipment
    Ku: 1.80m OS
    C: 1.80m PF
    Ku: 1.21m @ 7°w
    Hello Flie
    Malheureusement ton lien ne fonctionne pas ( erreur404)
    Pourrais-tu charger le nouveau streamreader sur un site de hosting ( par exemple workupload) et nous donner le nouveau lien , ce serait parfait. :76:
    Merci d'avance.
    Leider funktioniert der links nicht ( error404)
    Wäre super wenn Du bei einem Hostingsadresse es aufladet und uns den neuen Pfad gibst . :76:
    Dank in vorraus
    Unfortunately your link does not work (error404)
    Could you load the new streamreader on a hosting site (eg workupload) and give us the new link, that would be perfect. :76:
    Thank you
    stephan94
  • Files
    My equipment
    Ku: 1.80m OS
    C: 1.80m PF
    Ku: 1.21m @ 7°w
    Edited once, last by flie (June 9, 2019 at 5:32 PM).
