50.0°W Intelsat 29e END-OF-LIFE GS>Ku
Tonight scan, not sure if new...
12043 H 13330
New 11859 V 4765
Change , 12099 V 28330 ,now: 12117 V 45000
11860 V shows parameters only sometimes, for the most of time it is unknown and very low bitrate.
12043 H 13330 FTA, unknown but only one channel
203/20412116 V 45000 (enc)
2048/800X.. -
New TP 11832 V 1000, continous.
FYI: 11550 H left.
Thanks Marval 11832 V , very good signal
12153 V 1000
11973 H,30000,1/3-Vpid-8000(enc),Apid-8001,8003,8005,8007.
12071 H,1000,3/4,Dvb-S2/32APSK,ACM,Single-new GS
12153 V has left
new:
12188 V 2418 (weak)
12193 V 1000 -
12042 H 13320 "Service 01" Video
[SIZE=1]/edit by qwer: merged in GS>Ku[/SIZE]
Today check from my place both Pol.
New ,but very weak 12169 V 4000 .
Today's available low signals in V from my place
Including scan in H -
11842 V 14940
My scan, some TPs left . 12161 is new.
It is great ,that there is wrong polarity on FS for 4 months.
I can confirm the info on FS is correct, here is my scan.
You can see ,Feedsat and me, we have Vertical.
So show us complete scan. V+H
OK, as requested, here is my full scan, done H & V separately, 11800 to 12200. As you can see, there appears to be a signal on both 11843 H & V, but the H signal is stronger for me. I presume they are 2 different signals and not the same one showing on both polarities, normally that only happens if it's a very strong signal, whereas i'm only getting 5.1dB on H and just 3.5dB on V. Also, 11832 doesn't show up on my V scan at all. Does seem odd that you guys are logging those 2 signals on V though!
