Thanks milan58!
You have SR 20000 (-10dB, [16APSK] unlocked).
This morning signal increases a little bit at my place (SR 16000, -2.0dB, unlocked).
Thanks milan58!
Hi qwer,
now showed modulation.
if someone on the Internet showed images on this frequency?
12597,V,16000,23,8PSK
Thanks milan58!
Signal increases again (-1.0dB).
PS: Searching for PLS, but nothing found yet...
12599 V 16000 2/3 DVB-S2 8PSK is still active.
Haven´t got time last days for searching PLS... (tried: ROOT 205000-254000 already).
Danke für das "Nachfassen".
schöne Grüße
Übrigens, auch mit der CAS 120 (1.2m) sind die Parameter identisch:
12599 V 16000 2/3 DVB-S2 8PSK (2MHz Versatz mit Smart Titanium LNB)
Nahezu gleiches Signal (1.2m und 2.2m) >>> PLS...
PS: ROOT 200000-262143 bald durch.
No signal on 12599 V 16000 2/3 DVB-S2 8PSK this morning (6.55).
12599 V 20000 2/3 DVB-S2 16PSK is active here too now (-10dB NO LOCK, constellation monitoring looks also like 16APSK).
Tried on 1.2m and 2.2m.
/edit (7.15):
Only 20 minutes later, signal is back again with this parameter: 12599 V 16000 2/3 DVB-S2 8PSK (last attached files).
PS: Tried ROOT 5000-51791; 100000-137660; 200000-262143
(but not in BS, with fix parameter SR 16000 )
This is a strange frequency,this morning I caught this signal 12599,V,20529,23,QPSK,not can be locked (-10dB).
Tried GOLD 0-262143 in BS without success, in hope correct scanning...
Just for info:
Tried COMBO 0-262143 in BS without success, in hope doing a proper scan (12599 V), also scanning with TBS 6903...
Finally tried again ROOT 0-262143 in BS without success (TBS 6983)...
mühsam nährt sich das Eichhörnchen gerade im Winter
weiterhin viel Erfolg.
schöne Grüße
SR 20000 tonight
I don't know if 12598 V has a code pls,but in the desire to know why I/we can't lock this transponder,in the last three days I've been trying to find the code pls at 12598 V with symbol rate of 16000 Ks,and today again it was changed today,in 20000 Ks.I get the impression that it is a search in vain if it will change this symbol rate so often Unfortunately,the search code with the app's Crazycat is slow that it almost that you give up looking for this code
Hi satesco,
thanks for trying PLS search!
I also tried ROOT/COMBO/GOLD without success, even nothing found via BS (without fix SR).
So strange!!!
Not my catch.
Thanks to rasputin on Satcub Thüringen for locking this frequency again today.
11919 H 27500 3/4 DVB-S2/HD 8PSK
Package in clear (atm):
Sky Sports HD 1 (VPid 7002/APid 7003) and (VPid 7018/APid 7019)
Sky Sports HD 2 (VPid 7004/APid 7005) and (VPid 7020/APid 7021)
Sky Sports HD 3 (VPid 7006/APid 7007)
Sky Sports HD 4 (VPid 7008/APid 7009)
Sky Sports HD 5 (VPid 7010/APid 7011) and (VPid 7022/APid 7023)
Disney XD (VPid 7014/APid 7015)
Disney XD +1 (VPid 7016/APid 7017)
Disney Jr. (VPid 7012/APid 7013) and (VPid 7024/APid 7025)
BeIn Sports HD3 (VPid 7026/APid 7027)
Some double (adding V-and APids later on), test, I think...
whats about this tp? I don't understand.
onmy place there is only a reception of one tp, OTTHEVC.
signal about 13,5dB.
whats about the other tp?
There is no PMT, so you can scan this tp and get no results (see attached file).
danke Dir!
schöne Grüße
