Today "LOCKED"
10964 H 4250 DVB-S2
44.9°E Galaxy 11 (OLD POSITION Data>Ku)
AOL SR is now 12000 (a bit stronger here.)
Hi satesco,it´s from Astar 1F @44.5°E, hvdh and Feedsat already answered here, click!
PS: I will put this toppic in 44.5°E - later -.
Best Regards
qwer.Hi qwer,
Because I don't have access to the above link,I post on this topic active transponders that I've found.This satellite is not on FlySat list,but hvdh keep it in his table,and yet Astra 1F or Galaxy 11?( hvdh help) is active?
AOL has changed the symbol rate on 11006 H from 25000(yesterday) to 20000 Ks(today) -
Hello satesco,
I moved the posts above yours to the DX>Data 44.3°E Astra 1F topic:
http://www.satellitescommunity…ead.php?threadid=421&sid=Now, both Intelsat 904 (just arrived) and Galaxy 11 at 45.0°E are capable of 10.95...11.2 GHz. Is that the direction of what you're finding now?
The very nearby AzerSpace at 46.0°E will "push away" signals from 45.0°E slightly to the West, so that is explainable.
Let's wait for more reports before renaming this topic!Anyway, Astra 1F at 44.3°E has no 10.95...11.2 GHz. At Flysat, Astra 1F is listed under "EMPTY". Actually, it's me sending updates every now and then, for Flysat's Sat List!
Another AOL at 11162 H,20000,1/2,Dvb-S2/QPSK
es würde mich sehr überraschen, wenn starke TP auf 46 Ost es schaffen würden, noch stärkere TP auf 45 Ost wegzudrücken.
Bisher kennen wir den Ablauf, dass ein Satellit mit starken TP den schwächeren Nachbarsatelliten wegdrückt.
Hier passt dies m. M. nach nicht so. Oder irre ich mich? -
Hello Kleinraisting,
As you can see, above transponders received by satesco are very weak, not strong like the others on 45.0°E from Intelsat 12 Europe beam.
Frequency-wise, they could be either from Intelsat 904 or Galaxy 11.
Problem is, the Europe footprints of both should give a strong signal as well!Since no other reports come in yet, I'm not sure what sat and beam it is...
(in English, so satesco can read it too)
11005 H comes straight from 45E , strong 7db, 11162 H SR 12000 now, weaker max. 2 db, few steps to west needed(46E, 11175 H collision?).
This position is 0.16 ° wester than the Intelsat 12. These transponders are not new. I scanned them for the first time in November 2016.
now is better
Great, dreamsat!
Now I'm sure about Galaxy 11, that arrived at 45.0° on 20 October 2016, just before your first reception in November.
Your 4 signals fit in the frequency plan.Topic renamed and moved to Data>Ku.
Edit: possible Galaxy 11 Europe/N.Africa beam (ex-Conus).
And below: Intelsat 904 Spot 2. -
Thanks hvdh for your kindness,but for other languages there is google,isn't it?And I appreciate your good thought.
I'm surprised that only I can get this weak signal from this position with my antenna much smaller than the number of enthusiasts here.I really expect to be confirmed by others for transponders that I've found.
It would be good to give us a coverage map of Intelsat 904 and Galaxy 11,to see what we can expect to receive in our area from the two satellites.
Best regardsEdited:Thanks dreamsat for confirmation
10964 H 4250 Data
Not really good signal from France
Scan from my place - nearly same as Feedsats.
11192 H 13000
not a fake scan , always same SR found -
11192 H 13000
not a fake scan , always same SR foundYes, I can confirm this one too. :93:
The 11162 H ist a Data Channel
