I hope you all are working now on eutels. 33e on 59,5 east.........
there are a lot of bad things to see, especcially for qwer an kleinraisting
33e is on, not very strong.
thanks a lot, marval450 for checking
now we see, flysat has a wrong notice again;
11498 H 7270 8PSK 9/10 and not 4/5
this is the only tp who gives a small signal an my place (5,7dB, raining)
regards
A new topic for Intelsat 33e.
The provisional frequency plan, Ku-band downlinks only (by Capitan_Uncino):
Bem!
/edit:
What about 11555 H 28900 3/4 DVB-S2 8PSK (2nd scan)?
In my area the signal on Vertical is very weak,in contrast on Horizontal from good to acceptable.
On 10960 H is a test carrier now
It is from 62E.
It is from 62E.
Oops, okay thanks (not checked other lists first...).
Vertical is a bit stronger than was in my previous post.
Horizontal went down.
Hi hvdh,
If these maps of coverage for Intelsat 33E are valid,then,and as we see,both beams have signal of the same power,between 64 dBW and 54 dBW, but targeted on different areas.Distance from both footprints is equal in relation to of my area.Which polarity is used for one or the other?Or the last map,multispot,is the valid?
Thanks
My signal.
ZitatOriginal von satesco
Hi hvdh,
Thanks
I think if two spot beams are partly overlapping (like the 2 spot maps you posted), these beams will use different frequencies. Maybe different polarity is enough but I'm not sure... Hopefully after a while (and many signal reports) the transponder planning will become clearer!
The map at the right, just shows all the possible spot beams.
It also shows the wide beam, unfortunately as you can see on the frequency plan, only available on a few narrow transponders.
lower band from France is impossible to lock , nonetheless:
11622 V can be seen on 1.80m
I904: 4.2dB max
33E 0.5 dB
Best signal (6.6dB) on 11498 H from my place right now (1.45pm).
Of course still 4.4dB below lock.
on my place vacellating between 6,6 and 7dB......
regards
Horizontal signal suffers from night/day variation on the two frequencies:11490 and 11498 H.On Vertical is the same as yesterday,i.e. very weak in my area.
Hi satesco, I posted this in uk forum, seems opposite polarisations are used with partly overlapping spot beams!
Spot 34 (South European Russia): 11490 H = Krasnodar (Kuban24), 11498 H = Armenia
Spot 40 (North European Russia): 11503 V = St.Petersburg (L!fe78), 11521 V = Kaluga (Nika TV).
Hi hvdh,Thank you for update info
Strange,the signal on horizontal has disappeared for a while to enter on vertical.Because of this,I locked it with 110cm dish.It didn't last long as the signal return to the previous situation,i.e. stronger signal on horizontal.
It seems that they do tests of signal on the spots
Intelsat 33E ist jetzt auch mit der 2,20m Antenne erreichbar
