New TP , probably on IS 33e,
11465 H 21870
11465 H 21870
A new frequency
But the signal is weak
I hope the experience
11460 H 21873 3/4
Yes marval450 & atef 0, I bet it is IS-33e and made a fresh topic for it!
11465 is a 27 MHz transponder on the Wide (Eurasian) beam.
Almost 13 dB here.
P.S.: atef 0, I moved your 1st message to this topic and deleted the 2nd one and the php line.
Data comes at 11.2dB with 2.1m
Signal from my place (11464 H).
I think 11464 H is targeted on spot 40 and 33.Strong signal in my area.
There are 4 * 27 MHz transponders wide beam only: 11185 H/V and 11465 H/V.
This can be checked in the schedule S (pdf): http://licensing.fcc.gov/myibf…do?attachment_key=1085893
For 11465 H, Beam ID is KWHD, see the map below.
If it stays active (it was off this morning), this transponder could become a great reference to compare reception performance!
Because in theory, signal should be equal over a huge area (Europe & Asia).
(Contour lines: -2, -4, -6, -8, -10, -15, -20 dB)
My reception and with my big dish 3.4m
Still 13 dB here like in the beginning.
Pawelwa & dreamsat, Kypros' holds the record high now (17.3 dB) can it be beaten?
P.S.: I think I have the record low!
My Record today is 19,2
My signal.
New:
11579 V 6250 Auto ACM/VCM/cont./Multi
10970 V 3306 AVCM cont.
10970 V in my area.
Thanks
Goodmorning to all friends from Cyprus !!!
Springtime here and perfect weather for receptions (best period of year) - 22 degr. C
Reception of data this morning with 3.4m
New I think:
11531 V 2500 DVB/S2
New 11596 V 10581
Scan with 2,20m
10979 V,10853,3/4,Dvb-S2/32APSK,ACM,GS,Single
11009 V,34415,3/4-New transponder activated,but cannot get it lock
Generic Stream
11010,V,34410,34,32APSK
Merged last two posts by qwer in this toppic.
