It is DVB-S 3/4, I sent in the report to FS but he's put it in as 2/3 for some reason
24.8°W Alcomsat-1
Hallo
Bestimmt auf Alcomsat-1 ( in 12500 Bereich kann nur da sein oder ?)
Z.Z keine Übertragung oder so gering , dass man nichts speichern kann.
auch mit 1,20 m zu empfangen aber trotz 10dB bin ich 3dB unter dem Linc Margin
stephan94
Aus paris , heute fehlt mir was um beide Transponder locken zu können.
Well, 12240 now in 8PSK 2/3 .
Both TPs off , active only 12531 V 30000 data.
Active atm.:
12240 H 30000 2/3 DVB-S2 8PSK
Thanks for sharing!
I have around 7,5dB with a 78cm fix dish now. My first reception.
Even 12160 H 30000 is lockable now with 78cm garden dish. Just around lock (=6,6dB) and 1 dB weaker than 12240 H 30000.
Would be interesting to know signal at "flie" QTH.
Great, Afreaka!
Oops, forgot 12160 H. Just my scan on 2.2m.
Not such big signal difference between both TP as for smaller dishes,
on my place dishsize 120 10,7 and 11,3dB
Aus LIF mit 1,20 Laminas
12240 aktiv , aber nicht fliessend
Original von Afreaka
Even 12160 H 30000 is lockable now with 78cm garden dish. Just around lock (=6,6dB) and 1 dB weaker than 12240 H 30000.Would be interesting to know signal at "flie" QTH.
the signal is better with 0.90m here
12160 H 30000 --16.6dB...83%.
12240 H 30000 ---16.8dB ....84%: -
the signal is better little bit now !
12160 H 30000 --17dB...85%.
12240 H 30000 ---17.3dB ....87%: -
Signal here also not so bad. I think the beam goes over western Europe (France) more to the north. Dish only 78cm.
Signal here also not so bad. I think the beam goes over western Europe (France) more to the north. Dish only 78cm.goog signals Afreaka
but still there is some problem with these channels I think they are not ready yet
Tsreader crashes when I tray to open it with these channels ! -
To day morning "November 1st" is the officinal launch of Algerian TV in alcomsat1 according to the Algerian national TV
12240 H 30000 change FEC & modulation "QPSK 3/4 " OR SOME TING ELSE ! IQmonitor sow me different SR & Crazysan can't lock it ! some thing will happen here ?
I can't see any channels now in 12160 H 30000 8psk 2/3 ???! -
*ALCOMSAT-1 : PREMIERE ANNEE EN ORBITE
http://www.asal.dz/ALCOMSAT-1%…20ANNEE%20EN%20ORBITE.php*New coverage Map
https://www.tda.dz/node/4375 -
at least this time I can see all channels
there are more radio in 12240H that I can't get in one screen-shot !
here we can find all satellites that contain these channels
https://www.tda.dz/ar/node/3891
Les programmes TV/radio des entreprises publiques (EPTV/EPRS) sont disponibles sur les satellites suivants :
Satellite Algérien Alcomsat-1 @24.8° Ouest
Eutelsat E7WA @7.3° Ouest
SES4@22° Ouest
Arabsat Badr6 @26° Est
Eutelsat E5WA@5°Ouest
EutelsatHotbird 13D at 13° Est
EutelsatHotbird 13C at 13° Est
Intelsat Galaxy 19 @97° Ouest
Astra@19.2° Est -
this only i get from AlcomSat 1 @ 24.8° West with 4,7-8,8 dB on 0,95M-Dish from Germany
other TP need more maybe other time.
/edit by qwer: merged in this toppic + delete screenshot.
