Thank you Fidu.
So 11959 (L) and 12035 (L) is in my scan now from Russian beam.
Thank you Fidu.
OK, today I can confirm, the SSA TXP have moved to 36 C (not yesterday)
different scan, value and more TXP added 12359 12397 12439 12474 12205 in H nothing new in V
low signal but bad weather this evening in my place.
Before I could catch the signal to 12093 now catches the entire frequency range.
Tested on a universal LNB inserted plastic.
The picture is from this morning.
nice milan .
Today reduced power transponders.
Local oscillator settings for universal LNB 10600/9750(inserted plastic).
if you put local oscillator 10750 no half frequency.
ZitatOriginal von Feedsat
milan58: what is your local oscillator settings ?,
I think there is a mistake in your crazyscan chart ?
Am I wrong ?
You are right.
The plate is inserted wrong way(H =R, V =L).
All frequencies are shifted +150Mhz. bad LO setting.
New Frequency on SSA Beam 12129 H 27500 3/4
no lock yet...
edit: but not listed in the dstv NIT table.
Feedsat I would really appreciate if you could to a bandscan again because this DXer [URL=http://forum.satleo.gr/index.php/topic,10657.msg214834.html#msg214834]here[/URL] in Central Peloponnese with 1.80m Famaval and linear LNB has some transmission parameters different from yours that are now more than a week old. So I want to be sure that DSTV Africa has changed the values.
12265V seems also to have been activated since your last scan published here. Can you confirm this ?
Thanks in advance and best regards to all.
OK, no problem I will check it this week end.
But as you can see in my last scan, there is a mux on 12265 V.
Stay tune for more news....
Thanks. That's very kind of you. And yes you're right, 12265V was active in your most actual scan. I missed that because I was looking for a complete scan where all carrier data are shown so that I had seen the one of yours from 10.02.2016 and then 12265V was definitely not active yet.
By the way I've spent some time using your data and EXCALIBUR's from Romania (where Russia Beams are way too strong to interfere with SSA) to list up on the left all the active frequencies of Russia Beams and to the right the active ones from (Subsahara) Africa to make it easier for people between both coverage areas to clear which frequency comes from which Beam. That's why I am looking for most present and accurate transmission parameters of all. I hope that's ok for you ? I will also post the list here if anyone is interested in but right now I am not sure how many mistakes there are since I have no access to both Beams.
Anyway, I look forward in seeing your shots :)
OK, my scans of the day are attached, as you can see, today the signal is not really good (weaker than the 11th of February) but weather conditions are good.
I hope to be able to lock few more freq. , later...
12129 Pids
Excellent. Many thanks Feedsat.
Based on your results and those from EXCALIBUR 10 days ago this is the list I have made and updated now:
Eutelsat 36B/C Russia Beam Eutelsat 36B/C Subsahara (Africa) Beam
11727L DVB-S2/8PSK 27500 3/4 11727V DVB-S/QPSK 27500 3/4
11747R DVB-S2/8PSK 27500 3/4 11747H DVB-S/QPSK 27500 3/4
11766L DVB-S2/8PSK 27500 3/4 11766V DVB-S/QPSK 27500 3/4
11785R DVB-S/QPSK 27500 3/4 11785H DVB-S/QPSK 27500 3/4
11804L DVB-S2/8PSK 27500 3/4 11804V DVB-S2/8PSK 27500 2/3
11823R DVB-S2/8PSK 27500 3/4 11823H DVB-S/QPSK 27500 3/4
11843L DVB-S2/8PSK 27500 3/4 11843V DVB-S/QPSK 27500 3/4
11862R DVB-S2/8PSK 27500 3/4 11862H DVB-S/QPSK 27500 3/4
11881L DVB-S/QPSK 27500 3/4 11881V DVB-S/QPSK 27500 3/4
11900R DVB-S/QPSK 27500 3/4 11900H DVB-S/QPSK 27500 3/4
11919L DVB-S2/8PSK 27500 3/4 11919V DVB-S2/8PSK 27500 2/3
11938R DVB-S2/8PSK 27500 3/4 11938H DVB-S/QPSK 27500 3/4
11958L DVB-S2/8PSK 27500 3/4 11958V DVB-S/QPSK 27500 3/4
11977R DVB-S2/8PSK 27500 3/4 11977H DVB-S/QPSK 27500 3/4
11996L DVB-S2/8PSK 27500 3/4 11996V DVB-S2/8PSK 27500 2/3
12015R DVB-S2/8PSK 27500 3/4 12015H DVB-S/QPSK 27500 3/4
12034L DVB-S2/8PSK 27500 3/4 12034V DVB-S/QPSK 27500 3/4
12054R DVB-S2/8PSK 27500 3/4 12054H DVB-S/QPSK 27500 3/4
12073L DVB-S2/8PSK 27500 3/4 12073V DVB-S/QPSK 27500 3/4
12092R DVB-S/QPSK 27500 3/4
12111L DVB-S2/8PSK 27500 3/4
12130R DVB-S2/8PSK 27500 3/4 12130H DVB-S/QPSK 27500 5/6
12149L DVB-S2/8PSK 27500 3/4
12169R DVB-S2/8PSK 27500 3/4
12174L DVB-S/QPSK 4340 3/4
12190L DVB-S/QPSK 22500 3/4
12207R DVB-S2/8PSK 27500 3/4 12207H DVB-S/QPSK 27500 2/3
12226L DVB-S/QPSK 27500 3/4
12245R DVB-S2/8PSK 27500 3/4 12246H DVB-S/QPSK 27500 3/4
12265L DVB-S/QPSK 27500 3/4 12265V DVB-S2/8PSK 27500 2/3
12284R DVB-S/QPSK 27500 3/4
12303L DVB-S/QPSK 27500 3/4
12322R DVB-S/QPSK 27500 3/4
12341L DVB-S/QPSK 27500 3/4
12360R DVB-S2/8PSK 27500 3/4 12360H DVB-S/QPSK 27500 2/3
12380L DVB-S/QPSK 27500 3/4
12399R DVB-S/QPSK 27500 3/4 12399H DVB-S2/8PSK 27500 2/3
12418L DVB-S2/8PSK 27500 3/4
12437R DVB-S2/8PSK 27500 3/4 12437H DVB-S/QPSK 27500 3/4
12456L DVB-S/QPSK 27500 3/4
12476R DVB-S/QPSK 27500 3/4 12476H DVB-S/QPSK 27500 3/4
Big thanks to
EXCALIBUR (40km NW of Bucarest 1.4m PFA) for Russia Beams (source http://www.rdi-board.com/threa…25&viewfull=1#post1386225) 10.02.2016
Feedsat (Southern Central France 1.8m Offset) for Subsahara (Africa) Beam (source) 20.02.2016
Is the FEC of your non-locked frequencies reliable ?
I am asking because some just locked ones of 36C Africa Beam in the Peloponnese [URL=http://forum.satleo.gr/index.php/topic,10657.msg214834.html#msg214834]here[/URL] show different FEC (scan made with a Prof Revolution S2 7500 USB) compared to yours.
FEC ara 3/4 for QPSK and 2/3 for 8PSK
but during the first days, FEC was 2/3 for QPSK:
Yes I have registered that but the scans from Satleo member xristoss1965 are from yesterday so I am confused why the same frequencies show different parameters compared with yours.
For which frequency you have a doubt ?
I will check it carefully, but if this member czn lock them, the FEC is probably good and not 'mine'.
Here we have another fresh scan from Florence with 1.50m. Although there are a few frequencies missing (obviously a bigger dish is necessary) the transmission data on 12130H, 12207H, 12360H (those are not locked by your equipment) is equal to that from xristoss1965. This leads me to believe that the FEC might be not always correct if a frequency is not being locked.
Hi deepbluesky,
Although it seems impossible,it would be interesting to find out if someone receives both beams,Russian and SSA!?And in the case of,as I said-impossible,to get both,how looks like the signal on the analyzer?
And yet those in the south-eastern Europe are likely to catch the two beams?
Regards
Hello satesco,
4W is a similar case where some frequencies are used by Central Europe and Middle East Beams. vladan from Crete gets from both beams frequencies on his 1.80m Offset. You can see clear peaks in CrazyScan but some do not lock. It depends on which one is being received with higher quality. If both are same then there is no lock at all otherwise you get the frequency from that beam that has a much better quality. I also was wondering for a long time if there is a way to seperate the two multiplexes somehow but i got an answer that this is not possible at all. I had the idea in mind of data packages that are sent over networks and can be identified by 100% but something is different over satellite transmission so this mix of waves cannot be separated at all.
Now to 36E:
Once upon a time with 36A(W4) things were easier since there were no overlapping areas as far as I remember at least with dish sizes up to 3.7m. Either depending on the area one could receive either the SSA or the Russian Beam.
With 36B(W7) the coverage areas came closer. DXers here in S and in particular SW Germany like qwer made bandscans that were showing carriers but if I am not wrong he got some from Russia and others from SSA Beam.
As for the situation now that 36C started transmitting it is much more complex and that is what I am trying to find out but the research is in its initial phase. For SE Europe it is not easy to gather all the necessary data because DXers mostly post in their native language speaking boards. Further on speaking of greek satboards in particular I can tell you that there are just a few DXers dealing with 36E. Although there are reports but not too many yet. Up to now what I can see is that the 36C African Beam goes further East over Greece which in some western and central areas the Russia Beam has become (partly) unreachable. It seems that the overlapping area of both beams is bigger than of 36B. One example is that in Thessaloniki on 1.30m for the first time DSTV Africa frequencies could be locked and in Syros a Gibertini OP150 locked even more. Further South in Crete (just a little bit further East) Russia Beams seems to be stronger. In Cyprus 1m with circular LNB you can easily get 36C Africa Beam but 36B needs much bigger sizes. I am about to find out more.
