![](https://www.satellitescommunity.de/images/avatars/94/49-948717c462f9f7b72032d6ce0b133d664b21147b.jpg)
30.9°E Türksat 5A
Beim vertikalen Scan liegen 13048, 13084, 13426, 13825, 13832 und 13848 mit den Symbolraten über 1000.
Sofern dieser Frequenzbereich überhaupt für öffentliche Zwecke gedacht ist, dürfte das Empfangsgebiet ausschließlich die Türkei sein.
For vertical scan, 13048, 13084, 13426, 13825, 13832, and 13848 with symbol rates over 1000.
If this frequency range is intended for public purposes at all, the reception area should only be Turkey.
I think that all I am seeing is transponder noise but they could be real signals, I suppose. During testing, the DVB was receivable at 9-13dB SNR. The LNB is an SMW 12.25-12.75GHz PLL which had an 11.3GHz LO in 2021 but I have modified it to an 11.75GHz LO. The performance is only slightly improved with ~2dB NF, still not great. The notch in the 2021 plot is due to the LO spurious in band. I have about 0.15dB ground noise. The dish is a Prodelin 3122 1.2m offset.
I could only check horizontal polarisation but there were 3 signals today including the beacon. I used an SMW Q-PLL type R set to 11.3GHz LO. It's not great with a NF of 3-4dB at 13.6G. 1.8m dish.
Iv'e got the three up here again as well , usual beacon @ .401 , for me today the frequency hopping is between 13.415 V to 13.417 V. The strong marker at 13584.5 seems to be circular, possibly LHC. [ only using a linear feed onto a Chinese Universal Ext Ku lnbf on a 1.2m CM dish ]
