07.0°W Nilesat 301
  • Wrong (not up to date)
    Truth:
  • I used the other BWEI LNB L. O.:12.8GHz (13.75-14.5)
    seems that my BWEI LNB 12.8GHZ is not working well !!! :77:
    KooLy what BWEI LNB do you have ?
    the plastic one -like me- or the metallic cover one ?
    sorry it is irrelevant question, but maybe not all BEWI LNB works !!! :25:
    My equipment
    Ku: 1.80m OS
    C: 1.80m PF
    Ku: 1.21m @ 7°w
    C-Band LNB:Panorama ER861
    C-extended LNB: Bwei 5750Mhz
  • sorry it is irrelevant question, but maybe not all BEWI LNB works !!! :25:
    Maybe thats right. I scanned on Turksat - one scan I found transponders, next five minutes is nothing with another optical spectrum :80:
    Now I have order an PLL LNB for this frequence range.
    My BWEI is also with the plastic cover.
  • flie check your inbox I send Massage for You
    Thank you
    To 103.0°E
  • Scan of the day, nothing new...
  • 13460 H On 4K
    13574 H nothing new
  • 13460 H ONe 4K has left
    otherwise, nothing new (no active TXP in V)
  • 13460 H has left
  • Only 13553 V is currently working here.
    180 CM Jonsa
    TBS6983 - TBS6522
    Inverto Black Ultra
    Fuji LNB
    Inverto KaKu
    NJR2825 (KA BAND B)
    Norsat KA band 9000LC
    Norsat KA band 9000LDF
    Several C-Band LNBs
  • Sorry for responding too late. I was using the plastic one. ( The one on the left)
    180 CM Jonsa
    TBS6983 - TBS6522
    Inverto Black Ultra
    Fuji LNB
    Inverto KaKu
    NJR2825 (KA BAND B)
    Several C-Band LNBs
  • 13445 H 6000 3/4 OTT
    SATTUBETV
  • MPE on 201
  • I know
    SATTUBETV
    If I got this mux, I would try to use Ayecka SR1.
    Why don't you use it anymore? :3:
  • Time!!!
  • THe Video is active today for PID 256, vey bad quality @166 kbps....
    Available in H and V today (not a crosspol problem)
  • 13440 has left H & V, replace by 13438 V 27500 5/6 DVBS
    Emty TXP til now.
  • finally
  • H or V?
