10.0°E Eutelsat 10B
Kann mir jemand sagen, ob das Signal von Tele Tchad auf 3860 R an Stärke verloren hat?
Mit 125 cm ist da nichts mehr zu sehen. Oder wurde der Transponder deaktiviert?
Can anyone tell me if Tele Tchad's signal on 3860 R has lost strength?
At 125 cm you can no longer see anything. Or has the transponder been deactivated?
Signal wurde reduziert... 5,5dB über LM bei 4.9m (beim obigen scan waren es noch 11.5dB über LM).
3851 L 9165 3/4 DVB-S 8PSK, Ugandan mux in clear
Probably a new ID started....?
Sanyuka TV, but black screen at scan time.
Not my catch - N_Stanislav on LyngSat 24.01.2024
3954 R 4037 2/3 DVB-S2 8PSK, Télé Tchad (Chad)
No other changes since last scan.
...not active at scan time...
Its left...
Startimes Kenya Mux lockable again after long time skip with 175cm+Titanium LNB
3898R
3946 R 2083 3/5 DVB-S2 8PSK, AIT News is about 0.8dB under link margin on 4.9m from my place in current scan.
A new channel has been added to the StarTimes TV Kenya package
"XAVIER TV"
tr.3899 R 20150 DVB-S2 8PSK
3946 R is lockable again today morning on 4.9m.
I just had a scan done, the signal is stable around 6db. Antenna 270cm
Quite good signal today at scan time, about 4.8dB over LM on 4.9m.
