Who can lock 12719H? I see it for the first time.
57.0°E NSS-12 <ME/Europe>
Wow! First time signal in upper FSS band of NSS-12.
But much weaker here, can't see the QPSK constellation.
Should be Middle East beam (with weaker lobe into Europe). -
Same results like satesco from my place.
Same situation here, looks like strong peak but no lock :(
I made a new topic under Data>Ku for this NSS-12 high-band catch!
Surely not C-Asia beam, probably ME/Europe beam. -
No signal also from here
Astra 2D. There is a 2nd signal on 10940 H
10702 v still ok tooIs this signal in upper band is new ?
12720 H -
Yes, as you can see Satesco found this signal 2 weeks ago.
(Message moved from beacon topic to here). -
I have not yet locked 12719 H,but I found a signal similar to 12438 V but I'm not sure if comes from sat I'm afraid that is from interference because it appears on both polarities?
Could it be Express-AT1 at 56.0°E, 12437 R ?
I see only a peak at 12360 (Wide beam), but AT1 also has an Eastern beam that maybe gets through at your location. -
So I thought myself when you posted,but I checked the adjacent satellite-AT1,and at 12438 don't have a signal on wide spot,which has coverage on my area.It would be very nice to have a signal on East spot,but right now,apud FlySat,there is nothing.
Regards -
I have not yet locked 12719 H,but I found a signal similar to 12438 V but I'm not sure if comes from sat I'm afraid that is from interference because it appears on both polarities?Hi satesco,
yes, peak on 12720 H is still there, the other peak is always shown from my LNB on this range (also when there is no satellite near...).
I can see 12720H, nothing at 12348.
IQ finds this frequency 12729 H 1290 .
Checked many times.
Many transponders with low symbol rate found by IQmonitor app.No other application(Crazyscan or EBS) lock these trps.The signal on these is pretty strong and,so,I don't see how they would be fake.The constellations are very well defined,so they seems real.And yet I want others to verify them.Is someone curious to check out if they are real or "fake"?
ThanksAdded:high band files.
Hi satesco,
thank you for trying these low SR frequencies.
Maybe I can check some time later, when wind is not so strong here...
FYI: I merged your report in Data>Ku, probably some of them are GS.
Best regards
qwer, -
Hi Qwer,
As you already know,now that we have several devices/dvb-s cards that can do the job that we do not dreamed a few years ago,and with the help of applications that emphasize their capacities,I think that now it is more important to make sure that what we're picking it is true or not.For this reason,I'm not interested in how many of the transponders have low symbol rate I get,although this also matters, if those found have the correct parameters.It is true that such a question should answer the developer of the application we use.
So far I'm not sure whether to ask him or,as I think it's better,to check before if what I've received is really a correct parameter or a bug of the application!?That's why I am appealing to your help,because I also know that you're also interested in this.How do I think there are all the passionates on this forum.
So far IQmonitor is the only application we use that has reached a degree of refinement that the others do not have.But it's good not to be so confident in refinements,but more importantly,how accurate and correct this application works! I'm not sure of this at this time...
Thank you for your intention -
12642 H,5836,5/6,Dvb-S2,ACM,tbs6590 give me RollOff-0.05, while tbs6983-0.20!-Data
Thanks satesco
My signal. -
Hi satesco, nice catch again, I think > 12.5 GHz H is on the ME beam, do you agree this should be moved to that topic?
There is also a small chance, this comes from Astra 1G at 57.2°E.
Easy to check because Astra 1G has 3.5° inclination.
