11464 H 23000 3/4 8PSK
New SES Demo SD & HD
28.2°E Astra 2G <UK beam>
Only that I've got with my 1.50m antenna in my area from the UK spot :(
Guten Morgen
Dank die Möglichkeit von I/Q 1.0.0.7 automatisch Spectrum zu erstellen , habe ich heute Nacht eine Empfangvergleich von dem UKBeam aus LIF machen lassen ud davon einen Grafik gemacht
Hier kann man deutlich diese Schwankung sehen.
zwischen 20:30 und 22:30 keine grosse Änderung und plötzlich danach gehr es deutlcih nach oben. -
Danke, stephan94! :)
11181 H,20216,1/2,QPSK-I would ask you to check this frequency.Being far outside spot,I don't know if the signal is on this satellite or, who knows, it is a mistake of Crazyscan?!Definitely is a Data trp-AOL?
ps_Later increased the signal on Horizontal polarity between 11060-11200 MHz.Crazyscan could not lock this signal.Can you tell me what can be?
11181 H,20216,1/2,QPSK-I would ask you to check this frequency.Being far outside spot,I don't know if the signal is on this satellite or, who knows, it is a mistake of Crazyscan?!Definitely is a Data trp-AOL?ps_Later increased the signal on Horizontal polarity between 11060-11200 MHz.Crazyscan could not lock this signal.Can you tell me what can be?
Hi satesco,
sorry for my late reply. Now there is no signal on 11181 H.
Best Regards
qwer. -
Hi Qwer,
Thanks for checking that you have done :)I had hoped that entered a new transponder.
Kind regards.
satesco -
for stats here.
2F or 2G ? too lazy to check.
11185 V 2420 5/6, not really strong -
I cant find 2G toppic so Im making new one.
Thanks to winter conditions I can receive today 10963H , other TPs close to lock.
on my place some hours later; in the moment 11053 H 9,8dB
11068 V 23000 3/4
Hallo,
Welchen UK Beam Transponder würdet ihr mir zur feinabstimmung einer Laminas 2700 vorschlagen?
12023 H komm ich auf ca
18 dB mit Dr HD F16. Wäre dies für meine Region ok oder wäre da noch Einstellbedarf?
Qwer was meinst du dazu :)
Hello,
Which UK Beam Transponder would you suggest for fine tuning a Laminas 2700?
12023 H I get approx
18dB with Dr HD F16. Would this be ok for my region or would there still be a need for adjustment?
Qwer what do you think about that :)
12023 H typing error? Please give me another frequency to check - but UK beam should be very strong in our region... (not realy checked on my 2.2m dish).
PS: Allzeit guten Empfang mit der Laminas 2700 - supi!
11023 H 23000
BBC Schottland HD
BBC One Scot HD
Von meinem Standort habe ich einen Dauerempfang vom Beam G UK gemacht.
auch mit 1,80m bin ich wirklich an der Grenze was dauerhaft zu bekommen
11053 H stabil nur 50 Minuten lang
11068V stabil ungefähr 180 Minuten lang
11023H stabil ungefähr 4,5 Stunden lang
und am längste 11126 V circa 7 Stunden
selbstverständlch von Tag zu Tag kann es vollig anders sein.
( Messungen mit dem Programm von xone/123Sat gemacht)
From my location I did a continuous reception from the Beam G UK.
even with 1,80m I am really at the limit to get something permanent
11053 H stable for only 50 minutes
11068V stable for about 180 minutes
11023H stable for about 4,5 hours
and the longest 11126 V about 7 hours
Of course, it can be completely different from day to day.
Hallo
wie ich sagte , von Tag zu Tag können die Ergebnisse sehr unterschiedlich sein .
Gestern wieder einen Dauerempfang gemacht ( ein bischen spät am Tag)
Ich konnte viel länger die 4 Frequenzen von 2G UK beam empfangen
Wetter war ungefähr gleich wie am 28.
As I said, the results can vary greatly from day to day.
Yesterday I did another continuous reception (a bit late in the day).
I was able to receive the 4 frequencies of 2G UK beam for much longer.
Weather was about the same as on the 28th.
