15.0°W Telstar 12V
Who has reception here in Germany?
According to https://satkurier.pl/news/2342…ack-zmienia-satelite.html there a jamming signal on
11,014V (SR: 107140, FEC: 3/4; DVB-S2X/8PSK) using the Med Central Beam which also covers Germany.
Um 9:30 Uhr ( MEZ) gibt es hier kein deutliche Signal von einem Transponder auf 11043 V
At 9:30 am (CET) there is no clear signal from a transponder on 11043 V
Am Standort gibt es mit 125 cm ein Restsignal von 0.3 bis 0.5 dB und mit größeren Antennen könnte da was gehen.
At my location there is a residual signal of 0.3 to 0.5 dB at 125 cm and something could work with larger antennas.
In your region, even with a 40cm antenna, the transponder will work without any problems
But congratulations on the signal and best regards
Code
At 16:30 pm (CET) lock and all the 51 services found with all my receivers ( Technomate TM-5402 HD M3 ; Octagon SF 8008 ; Edision mio 4K + TBS 5927 USB ) Deltastar 90 cm dish , all +/- 12 dB Belgium (Flanders)
Now with image. Encoded in BISS.
/edit by qwer: Please don´t show encrypted content in clear.
I just checked on the 270cm antenna in Sweden (near Malmó) there is no signal from the new BBC-Satback beam
However, the signal must fall very quickly towards the north.
I think they works in North Sea beam.
I don't think footprint is "north sea". Signal here in Finland is only 1-3db, tested with 2.4m and 1.8m.
You are in an area with 11043V/11014V interference
How can these disruptions be avoided?
Will it always be like this? Can anything change in broadcasting?
Can't avoid physics law
