26.0°E Badr-6
Latest reception of sat
Hi, all!
Few days ago, moved my satellite dish reception positon, to 26E Badr6 satellite.
My system komponents, with to the receptions :
Andrew ES37
Invacom QTF-031
Self designed, and maked waveguide, and feedhorn device
Satellite receiver, GoldMaster SR-525 (With the super sensitive DVB-S tuner)
The weather was fine, sunnyes, the outside temeratures the sames with season, 5-7 Celsius, little wind.
The reception is now better than last year May.
I need one more setting, to better that receptions, because the LNB Skew setting not rotated appropriately, I had little time. Momently LNB Skew settings, the 28E UK beams.
Bests, regards
SaTom
I got Badr6 today
I'm super happy
Antenna 240cm
Just a second to lock :)
11747 V
Ich gehe davon aus , dass die Frequenzen von Badr6
jetzt von einem anderen Badr gesendet sind ,
und jetzt einfacher zu bekommen sind.
bei Mir auch kein Problem mit 11747 V und 11785 V
I assume that the frequencies from Badr6
are now broadcast from another Badr ,
and are now easier to get.
No problem with 11747 V and 11785 V for me either.
Latest reception of 11747 Ver
Hi all Dear, DX-r friends!
Dx Bozóth, and me, yesterday, making the reception report, in the 26E satellites.
Please read it, the report. :-)
http://www.netboard.hu/viewref.php?post=17767110
The report, writed to Hungarian language (Sorry, momently not translated me, beacause too long, and too have technically words.). I recommend, use to gooogle translater, or other alternative.
Thanks, for watching, have nice day!
PS:
I welcome all corrections, comments, clarifications and additions.
Best, regards!
SaTom
Mein Empfang beider Transponder mit 1,8m, schon deutlich weniger im Nordosten als bei stephan
...checked them in "manual scan" via CrazyScan on 2.2m at my place:
12341 H up to -1.3dB
12379 H no signal
12399 V -10.0dB
12418 H -10.0dB
12437 V up to -2.8dB
12456 H no signal
12475 V no signal
So I´m out of here... I think these ones are not (anymore) from Badr6...
I think ,all TPs are now on Badr 5. I lost all from B6, only signs of signal on some TPs ,max .0,5 db...
Gibby 150 - scan November 2022 and today.
I'm also guessing Badr 5 - MENA beam
Latest scan
Im Westen was Neues:
Am Standort heute eine Premiere, mit der ich nie im Leben gerechnet hätte:
Empfang des ME Beams mit 125 cm:11862 V 27500
11785 V 27500Nur Pixelsalat, aber immerhin ein brauchbares Signal.
Antenne: 125 cm Kreiling Spiegel.
LNB: Inverto Flansch LNB in Kombination mit dem Gibertini Feedhorn. -
Das Signal auf beiden Transpondern ist noch vorhanden.
Auf 11862 V reicht das Signal mit 4,5 dB sogar trotz bewölktem Himmel aus, um den Content der Programme sehen zu können, wenn auch mit starker Verpixelung.
Grüßesatdxer
Nachtrag: Auf 11747V erscheint nach einigem Warten ein Signal mit 3,8 dB. Zu schwach zum Einlesen der Programme. -
Hier ein Spektrum (vertikal) vom gestrigen Abend. Empfang mit 125 cm.
Grüßesatdxer
Ja, diese Transponder vom Badr-6 sind bei mir nun auch grenzwertig empfangbar. Anbei ein Screenshot aus 2018 wo ich
die 11785 V mal mit 2,2m empfangen konnte.
Nun sind diese beiden auch mit 1,8m möglich.
