Today another catch from ca beam. The signal seems to waver periodictly
After scan there were found the transponders, but short time later no signal...
My scan from this position (2.2m).
Locking 11015 H and 11174 H.
Too low signal atm on 11027 H (up to 7.2dB).
And a look on the other polarisation.
Lockable here: 11039 V and 11094 V.
Has anyone managed to lock 11071 V,1666,9/10,32APSK with the good signal?
Edited:added IQmonitor report
Yes , the one with min. 13m ESA in the garden...
Locking value is 16.1db .
:27: :27:
I have a ESA but I have no garden.But even if I had the garden,the neighbors would be outraged that the antenna will cast shadow on their home :27:
Thanks for "trying"
My reception with 2.1m but with different SR
My receptions of Europe Beam & C.Asia ( 11095 H&V)
With our dvbs app/tools,11071 V signal is weak regardless of the size of the antenna and the reception area,at least as shown on @Qwer's spectrum, mine and yours,below 2 dB.I think it's more than that.
Without joking,as I did above, probably 11071 V has a mis or pls code? Of course I'm not sure of that :93:
And there is something else, IQmonitor will show you another symbol rate value if you scan several times.That's why Crazyscan is more relevant than IQmonitor in some cases,and this transponder really has 1666 ks.
Regards
Regards
I agree completely with you my friend . Personally i prefer to use EBSpro ( not supported anymore ) and after Crazyscan
Regards
Signal of the night ... from my pace NW Italy (4,2 Mt)
11027 H -> ARAS TV ERZURUM - Just now colored bars
Bad situation for 11071 V
My scan (10950-11200 Hor ) with 2.1m
Kypros_Pambou
your spectrum looks weird, try to mark "auto" in upper left corner.
Kypros_Pambou
Hi marval450
You have to know that if you mark " auto " on RF Scan is possible to loose the minimum SNR of a transponder.
That's why i prefer to put my RF Level limits (40 to 68 dBm) on the specific software
ps: I put the same RF scan with mark " auto "
Spectrum should look same like in crazyscan or EBS, nothing is visible on yours .
Try to pull scale up an down, 46 to 49, 59 to 51 .
My spectrum looks normally.
I agree with this but not in "auto" situation as you said before
11004,H,2498,56,8PSK
Again this frequency is currently being broadcast only for a radio program.
[46.0E] 11049 - Vertical - 14996.834 - 2/3 - DVB-S2/8PSK - CCM
Exact channels as on 11095 V
Hallo
Heute aus LIF mit meine 1,20m einen Transponder vom AsiaBeam bekommen.
