I assume your 1.8m antenna is not motorized, you rotate it manually? Did not find any signal at frequency 3928H SR1790 from position 17E?
IQmonitor tool
Hi all,
sorry for my question, but (how) can I change the stream parameter from "udp 2103" to "tcp 6969" (for example)?
Hallo ,
soweit ich weiss , kann man nicht .
ich muss sagen , damit habe ich nicht so probiert ,
vielleicht gibt es trotzdem eine Lösung .
as far as I know, you can't.
I have to say, I didn't try that
maybe there is a solution anyway.
Only that can be changed by a programmer.
Okay, thank you guys.
Videolan released a new player version.
Still Ihave not tested with IQMonitor, but don't forget to change the IQMonitor.ini in the parser section (VLC=.............).
for example with standard directories:
VLC=C:\Program Files (x86)\VideoLAN\VLC\vlc.exe => VLC=C:\Program Files (x86)\VLC Plus Player\vlc.exe
or 64 bit
VLC=C:\Program Files\VideoLAN\VLC\vlc.exe => VLC=C:\Program Files\VLC Plus Player\vlc.exe
yes I rotate it manually.
unfortunately no signal for 3928,H,1790 or 4137,H,19410 here ! trayed many times !
An other Crazy Test @ 24.8°W
just I thought that these "fake" transponders are in Circular polarity !
12717,V,4550
12725,V,9100
12734,V,7583
12742,V,5308
...apparently they are not
IQmonitor Pro software is the best of its class for DX-eras and Feed Hanters for searching and deep analysis of DVB-S2 signals. It implements a number of exclusive algorithms and procedures that are based on tunnel computing technology with an efficiency of more than 800%, which made it possible to expand the range of capabilities of both budget and professional PCI and USB cards both in frequency (up to 3 times) and in resolution. and the accuracy of the spectra of DVB-S2 signals (up to 4 kHz). The interface of the IQmonitor Pro program is described below, which is not only a universal tool, but also a personal certificate of the highest user skill. The program is freely distributed on the site satellitescommunity.de
_____________________________IQmonitor Pro interface_______________________________
1 - The main window of the program with an indication of its version and username / nickname. Optimal for SVGA format
2 - The operating window of the program can be scaled for optimal output of RF and HR spectra.
Many elements of the IQmonitor Pro interface have hints that appear when the cursor is delayed within an element. Read the hints - they often contain additional information about the function of an interface element or recommendations about the value of the parameter that is set in this element.
Discussion of the IQmonitor Pro program in Russian - at the link https://filatov-yuri.livejournal.com
Discussion of the IQmonitor Pro program in English and German - https://www.satellitescommunity.de
My friend stephan94, who has contributed to the development of the program for many years, has submitted many valuable ideas and suggestions for its improvement, has translated this instruction into German. For this, respect and gratitude to him
Free download of files related to the program - by the link ---> IQmonitor - Only files ! There you will also find instructions for installing the program and conditions for obtaining a personalized key to IQmonitor Pro
@stephan94 habe gerade eine Video von IQMonitorPro mit dem Gistogramm
Du kannst diese Video hier herunterladen
IQMonitorPro mit Histogramm - Registrierung des HF-Spektrums mit Anzeige von R-Signal-Histogrammen
Many thanks for IQmonitor Pro Yuri.
It's unbelievable. I've only tried a few features and they all work perfectly. There are a lot of improvements I haven't had time to try, but I'm excited about it. As Stephan writes, I don't know where you get the strength and ideas on how to solve our requirements. When I test a little more features, I'll write my experience.
Hallo,
Für diejenigen , die mit dem Links oben schwierigkeit haben
zum Beispiel mit Firefox will es nicht gehen ( warum auch immer)
hier einen andere link
https://workupload.com/file/vYC6jLCdLMR
viel Spass damit.
Inzwischen sind die "Wartungsarbeiten" beim Link beendet und er funktionierte jetzt.
Anleitungen habe ich nun genug, in drei Sprachen, angesehen und mehrfach gelesen.
Ich hoffte gestern, dass der Link endlich funktioniert.
So ausführlich, vorallem als "Gesamtpaket" gab es eine Anleitung noch nicht, da ja der IQMonitor ständig gewachsen ist, sehr lobenswert.
Ein extra Danke an Stephan für die gelungene Übersetzung.
Für mich stellt sich aber die Frage, was fange ich blos damit alleine an
. . . . . . . . IQmonitor Pro ver.1.0.0.0 .
To install the IQmonitor Pro program, you need to unpack the IQmonitor_Pro.zip archive and get the IQmonitor_Pro base directory, which contains the base of the program database, StreamReader and other files necessary for the program to work
Then unpack the archive IQmonitor_Pro_1000.zip (where 1000 is the number version of the program) and copy IQmonitor_Pro.exe to the IQmonitor_Pro folder
This completes the installation of the program, you can run it and enjoy the wide possibilities that will open before you
Having mastered this or that function of the program, share your results in the this topic
ATTENTION ! Publication of your materials on the forum http://www.satellitescommunity.de is a REQUIRED condition for obtaining a personalized key to the IQmonitor_Pro program
When you decide that you have mastered all the basic functions of the program and confirmed these are your publications on the forum, you lead the best in the topic (according to your opinion) the result of using the IQmonitor_Pro program and submit an application to receive a personalized key to the program, which opens Advanced functions
When the moderator decides that you have sufficient command of the program, the file IQmonitor_Pro.key will be sent to you through the system of private messages, which you just need to put it in the IQmonitor_Pro folder.
Good luck! Respectfully yours, Yuri Filatov
The first tests with IQmonitor Pro made a big impression on me.
I appreciate the advanced BlindScan settings, step, bandwidth and more. This allows you to set the optimal conditions for searching for transponders with SR from 100 - 67500 (max. For TBS6983). This is how IQmonitor finds all TPs on the satellite.
I would welcome the dF extension for 5760 pix. As it was in version 2407.BlindScan:
Also, the "Paint" button does not work as in the previous version. H+V, Maybe it's an intention or I'm making a mistake somewhere.
After "Paint": It freezes for a few minutes and then renders this.
I didn't try to control the positioner because I don't have DiSEqC motors. (My antennas wouldn't tighten.)
@Peon , thanks for the beta-version test.
I will ask you to replace it with ver.1.0.0.0, which is posted in the public
When displaying, plz, use the "Auto" checkbox carefully and never with the "Add" enabled
We'll talk more about expanding the tablet, but 90% - no.
ZitatI didn't try to control the positioner because I don't have DiSEqC motors.
- do you have rotary antennas with DiSEqC control ?
Eine Bemerkung, um diese Frage zu vermeiden :
Warum bei meinem Blindscan wurde nicht alles gefunden ?
( es betrifft nur accurate RF spectrum ; normal spectrum und express spectrum)
Zwischen der alten Version 2407 (und der vorherigen)
die Präsentation wo man die Breite und skew eingegeben kann
ist ein wenig anders.
Hier ist ein Bild mit der alte und neue Presentation
aufpassen in der version PRO sind an Anfang die eingegebene Zahl ziemlich gross.
A note to avoid this question:
Why wasn't everything found during my blind scan?
(it only affects accurate RF spectrum; normal spectrum and express spectrum)
Between the old version 2407 (and the previous one)
the presentation where you can enter the width and skew
is a little different.
Here is a picture with the old and new presentations
be careful in the PRO version the number entered is quite large at the beginning.
viel Spass
