• lt. einem engl. board gibt es bereits erste TP auf Badr 7,
    einer ist der DVB-S-TP 11881 H 27500
    der hier mit einem noch relativ günstigen -dBm-Wert (52) wahrgenommen werden kann (NWA beam); die TP des MENA beams haben alle um die -68 dBm, sind also verdammt weit weg.
    Wer kann mal den 11881 H testen?
    1 Gib. 150
    1 T90
    1 Gib. 125
    Edited once, last by Kleinraisting (July 20, 2016 at 1:50 PM).
    Hi Kleinraisting,
    absolutely nothing from here (2.2m), according frequencies in posts #88 and post #94 on satellites.co.uk.
    PS: Even nothing in spectrum.
    /edit:
    12730 H 4165 DVB-S2 is here from Badr-4 (attached file 1)
    12728 H 27500 3/4 DVB-S2 8PSK Badr 7 Mena, according user satclub (Tunisia) on satellites.co.uk
    or:
    12563 H 2220 3/4 DVB-S, Feed on Badr-4 (attached file 2)
    12563 H 27500 5/6 DVB-S QPSK Badr 7 Mena, according user satclub (Tunisia) on satellites.co.uk
    or:
    12602 H 2960 5/6 DVB-S, Feed on Badr-4 (attached file 3), also active here 12615 H and 12619 H on Badr-4
    12604 H 27500 3/4 DVB-S QPSK Badr 7 Mena, according user satclub (Tunisia) on satellites.co.uk
    :125:
  • I think that something new started here
    11270 V 27500 8PSK 2/3
    friendly FEC.
    interesting is test card with HELLAS-SAT info known very well from 3*W.
    Or maybe this is a BADR-7? someone can confirm?
    Original von Tomek22
    friendly FEC.
    Thanks Tomek22 and Kypros_Pambou!
    Nothing right now from my place on 11270 V.
    Original von rysiuhelix
    Pack MBC .
    7,2 dB Dr HD F-16 - Laminas AS 180 .
    No signal at my place on 11270 V. :88:
  • In my place signal is much better.
    In Poland pawelwa and @Harti got problems with reception. In central Poland its available with only 1.80m.
    7.6dB with little rain outside
    Maybe this is really badr-7 becuase coverage of this beam is weird.
  • Big thanks guys, nothing at all here at my place. :90:
    I locked the dish at this position atm. :91:
  • According to the reception reports for 11270 V it can´t be Badr-5 Pan-Arab beam. Probably I had to start a new toppic Badr-7.
  • sehe das auch so :88:
    schöne Grüße
    1 Gib. 150
    1 T90
    1 Gib. 125
  • Here is my early afternoon situation for the full band both Pol. from 26°East with 4.2Mt. Location: North West Italy
    Very hard to lock 11270V, no chance for 11227V. Maybe better in the evening. Some interference from Astra 28.2, I think
  • Vielen Dank Carmen! :69:
    Etwas ist heute am nachmittag geschehen. Gestern noch unmöglich (11270 V).
    /edit: Maybe NetworkName: "ArabSAT NW" means North-West beam... (joke) :83:
    Incredible qwer!!! Bravooo :94: I Think I need to make some works on The roof...
    DH 4.25M for KU H/V/L/R, C H/V/L/R–HH+Elev
    KUH/V: ADL KU920+OMT
    KUH/V: 2 SMW WDL DUAL ULPN
    C 5G: 4 AVCOMM L1508F 3.9-4.2 or 4 Norsat 3100-BPF-4 3.8-4.2
    RC2000C-3 VBOXIII
    TBS5925,5927,6983,2 6908,6903X,6909X,V8UHD,GTCOMBO
    Feed changer on the way: LinearMoto, RotorFeed skew adjust
    28.2E Gib125,5W CM120,30W CM120,19.2E GBC80,13E GBC80+SCR
  • da schließe ich mich mit 5,9dB gerne an; nur, der F16 kann den grünen Balken beim Suchlauf nicht halten.
    Dank und Gruß!
    1 Gib. 150
    1 T90
    1 Gib. 125
