Neue StreamReaderEX-BDA
NEW :
stream-reader 1.2.4.83 (22-07-2019) ...Correction in bandwidth compiler.http://crazycat69.narod.ru/sat…/StreamReaderExEx-BDA.rar
many thanks to Crazycat & Strannik
stream-reader 1.2.4.83 - modified (12-01-2020)
Added support for DD card....I think ...and more :
https://rickcaylor.websitetool…eeware-8427111?&trail=150always the same link :
http://crazycat69.narod.ru/sat…/StreamReaderExEx-BDA.rarmany thanks to Crazycat & area21
This is the fourth version with the same number,
Thanks. -
Original von flie
Well ... and moreBlindscan don't work with IQM 2.2.0.9. I must reinstall now the older version on all devices and directories
Here the same on EBSpro:
Original von femi
You're right ... there is a problem with this new version:
This new version might be useful for "DD Cards" but it's not good for me either!
I will use the older version:1.2.4.83 (22-07-2019)
My posting was related to version 1.2.4.83 from 12.1.2020, but a few minutes ago I have tested the version 1.2.4.89 from last night, but it's the same problem as you wrote.
I'm using version 1.2.4.83 from 23.12.2019 23:37, that's OK too.
Streamreder 1.2.4.95 and 1.2.4.96 is working with TBS 6925/6908
EBSpro and IQMonitor 2.2.0.9, newer version not available to test -
Original von femi
EBSpro and IQMonitor 2.2.0.9, newer version not available to testEBSpro BETA v17.0.0.0
Please ask flie again.
I wrote test with IQMonitor 2.2.0.9 because a newer version is not available for me.
EBSpro BETA v17.0.0.1 install another version of streamreader, same date, but another time. Who (like I) have problems, should change the streamreader with this of the link from flie, 3 postings bevore!
Femi, take a look at this page, I think this is the solution to your problem:
Original von Lambda
Femi, take a look at this page, I think this is the solution to your problem:To my deep regret, I can not upload archives with the program in this wonderful forum, so the link to download the program can be found here:
https://filatov-yuri.livejournal.com/7075.html
By the way, I already gave this link in the IQmonitor branch
Original von strannik
Hi strannik,
thank you very much for your work and this great program!
I tried myself to upload this rar-file, but it does not work (20MB are possible) - I have no idea, why it is not possible to upload this file, sorry!
Hi strannik,thank you very much for your work and this great program!
Good health, qwer!The fact that a large archive cannot be stored in the forum database is not good, but not deadly.
Moreover, I will send new versions of the program individually only to those users who published the results of their work with the previous version.Success and 36.6 °!
Hallo qwer,
ZitatFehlermeldung
Der von Ihnen gewählte Dateityp ist nicht erlaubtZitatErlaubte Dateiendungen: gif jpg jpeg png bmp zip txt
Max. Dateigröße: 20 MB
.rar Archive sind in der Liste der erlaubten Datei Anhänge nicht aufgeführt, daher wird es nicht funktionieren. Wenn du im ACP des WBB die Liste um .rar gepackte Archive erweiterst, sollte es klappen.Ich habe gerade etwas herum probiert und komme zu dem Schluss:
.zip Dateien bis 5MB einzelne Datei Größe lassen sich problemlos anhängen. Bei 9MB Archivgröße bricht der Datei Upload irgendwann ab, ohne Fehlermeldung. Die zuvor zum Upload ausgewählte .zip Datei mit 9MB Größe ist im Auswahlfenster gelöscht und im Upload Fenster kommt die Meldung keine Datei ausgewähltVermutlich hat dein Hoster selbst eine max. Größenbegrenzung für eine einzelne Datei im Upload (unabhänig von den eingestellten 20MB im WBB), die demnach bei 5MB liegen dürfte
Okay, danke euch beiden!
Nachtrag: Ich habe um rar ergänzt, leider scheinen 9MB tatsächlich zu groß zu sein.
/edit: 6.8MB habe ich probiert, die gingen noch.
Original von Lambda
I am happy to have a working program. Thanks strannik.
I then write everything else in the IQMonitor thread.
