Neue StreamReaderEX-BDA
  • StreamReaderEx for BDA v.1.2.4.128-26.06.2022 (new)
  • New StreamReaderEx for BDA v 1.2.4.133-13.07.2022
  • Tested StreamReader files with McAffee and Malwarebytes Premium. No viruses detected!
  • Acronis (Static ML), Ad-Aware, AhnLab-V3, Alibaba, ALYac, Antiy-AVL, Arcabit, Avast, Avira (no cloud), Baidu, BitDefender, BitDefenderTheta, Bkav Pro, ClamAV, Comodo, CrowdStrike Falcon, Cylance, Cynet, Cyren, DrWeb, Elastic, Emsisoft, eScan, ESET-NOD32, F-Secure, Fortinet, GData, Gridinsoft, Ikarus, Jiangmin, K7AntiVirus, K7GW, Kaspersky, Kingsoft, Lionic, Malwarebytes, MAX, MaxSecure, McAfee, McAfee-GW-Edition, Microsoft, NANO-Antivirus, Palo Alto Networks, Panda, QuickHeal, Rising, Sangfor Engine Zero, SecureAge APEX, SentinelOne (Static ML), Sophos, SUPERAntiSpyware, Symantec, TACHYON, TEHTRIS, Tencent, Trapmine, Trellix (FireEye), TrendMicro, TrendMicro-HouseCall, VBA32, VIPRE, VirIT, ViRobot, Webroot, Yandex, Zillya, ZoneAlarm by Check Point, Zoner
    all undetected
  • StreamReaderEx for BDA v 1.2.4.133 from 19.07.2022
    -Set freq step for AirScan to 3 MHz
  • StreamReaderEx for BDA Tuners v. 1.2.4.137 from 15.10.2022
    "DiSEqC1.0 (04 lnbs ) * STAB USALS" is not working good for me in this streamreader 124137 ? :40:
    always I see spetrum from A/A1 lnb !
    also I don't have TBS5925 !!! :25:
    no problem using for example the older streamreader 124120 !
    always using the same crazyscan version 102178 :25:
    I don't know if i wrong or not :40: but I don't have problem with IQmonitor with the same streamreader 124137 !
    Edited once, last by flie: adding more info ().
  • remove Multiswitch , only Diseqc (1.0) and Rotor (1.x)
  • Always the same problem even with older Crazyscan version 102168 and this new streamreader 124137 !!!
    always I see spectrum from A/A lnb ! and also TBS5925 !!!!
    the problem is this new streamreader 124137 I think :25:
  • Hello fie,
    the streamreader don't switch diseqcs.
    I have tesetd the latest CS 178 and all diseqc's are working (A/B and B/A are twisted in Crazyscan)
    As far as USALS is concerned, I can't try anything unfortunately.
    I think the problem is with the diseqc switch.
  • I have tesetd the latest CS 178 and all diseqc's are working
    very strange ! are you using streamreader 124137 with cs 102178?
    because when i use streamreader 124137 devices list changed also diseqc not working well ?!
    but when I use streamreader 124133 every things work!
  • are you using streamreader 124137 with cs 102178?
    yes
    in my streamreader.ini:
    ;! Voltage boost (+1V)
    VoltBoost=0
    ;! Force High voltage before Diseqc cmd
    DiSEqCHV=1
    you can also try
    VoltBoost=0
    DiSEqCHV=0
  • yes
    VoltBoost=0
    thank you very much femi :70::74: for advice ,it was voltboost which make this problem to me :73:
    I remember one time strannik :70: talk about it here , but I didn't realize it until now ! :77:
  • StreamReaderEx for BDA v.1.2.4.140 from 2.01.2023
  • 1.2.4.140 - Some fix for m88rs6060 based devices like 6902se, 6904se
    not enough fixes :26:
    With Crazyscan, there is no noticeable difference to the previous version, at least not when running through it quickly on Astra 19.2°E (95 transponder were found).
    EBSpro reports "Blindscan not supported", "should be continued with Blindscan2 (96 transponder were found)"
    With the IQMonitor, everything stayed the same. Spectrum works, but both blind scan variants are not supported.
  • You can write to him on Telegram yourself if you think he is not trying hard enough :40:
    Why do you think that changes must be visible in Blindscan?
  • Ich will damit nicht sagen, dass sich nichts geändert hat, jedenfalls ist es auf den ersten Blick nichts Auffälliges und trifft auf alle erwähnten Windows-Programme zu. Mit Blindscan hat es nur insofern zu tun, ob er funktioniert oder nicht.
    Fall jemand die Verbesserung findet, kann er sie gerne hier kund tun.
    Persönlich wäre mir eine besser funktionierende 6903x ohnehin lieber, angeblich kontaktierte TBS auf meine Anfrage crazycat, geholfen hat's nichts.
    Das Problem liegt meistens an nicht verfügbarer Hardware.
    I don't want to say that nothing has changed, at least at first glance it doesn't look anything special and applies to all Windows programs mentioned.
    It only has to do with blindscan insofar as it works or not.
    If anyone finds the improvement, please feel free to post it here.
    Personally, I would prefer a better-functioning 6903x anyway, allegedly TBS contacted crazycat on my request, it didn't help.
    The problem is mostly due to unavailable hardware.
