IQMonitor itself reads the .trs folder it created.
you can also read the .trs with Notepad++
Oke ,
and with what Program in (Parser)
Mvg
Oke ,
Mvg
None, it's created by IQMonitor for IQMonitor
Hier ist ein Video, das erklärt, wie
man Transponderliste erstellt
und danach wie man diese Liste sehen kann
Here is a video that explains how
create and display the list of transponders
Ich habe schon viele Videos gemacht, die wie man mit IQMonitor arbeitet erklären
Fast alle sind im Forum , einfach suchen und sie sich anschauen.
I have already made many videos explaining how to work with IQMonitor
Almost all are in the forum, just search and check them out.
channel list is working.
good job .
Mvg
How doe i change the settings in the Player : ABC 4T2
Mvg
Mvg
Hier herunterladen und lesen
Download and read here
Download en lees hier
http://www.4t2.eu/Download/4T2SWManualContent-AnalyserEN.pdf
Most of the program`s are working.
only VLC hase or have or give a little bit of problems.
Mvg
You must have a registered version (I don't think you can register anymore, support has ended) or have a TBS5925 card connected to your PC. It works with the TBS5925 card as with a HW license.
Hallo Peon.
i have a TBS5927 and bought i license.
ore must you pay every year.
And can you tell mee whot the Settings are ?!
Mvg
Strange ; Support valid.
i read it at my account at TsReader
Mvg
Perfect.
thank you.
Mvg
Can some-body show mee how i can use the 4T2 Content Analyzer with my TBS5927 and the satelliet on 26.0 East.
thank you
1. Make a spectrum
2. Select a transponder and with right mouse "tune to frequency"
3. close view and stop vlc
4. press ABC 4T2
ABC 4T2:
Input/Output use TS-File for Input, TS-File for output (select an output folder and file name, where ever)
It depends neither on the satellite nor on the TBS-card. If the mode of the transponder is also supported by the card.
