Just for stats...
Nothing new.
Just for stats...
Nothing new.
16°E
12627,V,2450,56,8PSK Can anyone check this out?
ZitatOriginal von milan58
16°E
thanks for checking the pawelwa, now active frequency
12624,V,2449,56,8PSK DSNG Mazda,frekvency feed
There is already a third day as the signal is weak, maybe the PLS code?
12574/V/6500 2/3 8PSK(DVBS2)
without PLS, maybe dual mode
New frequency 11070.070,H,375,35,8PSK-Sky Radio TNZ,Veronica TNZ
Let's go girls and boys who can lock this signal?
ZitatOriginal von satesco
Thanks milan58
12574 V,now is 6000,fec unknown?
I can not lock this signal,so please whoever can to tell what contains this transponder?
Regards
not PLS
file = tuner/tuner_interface.c,
line = 320
fun = TUNER_SAT_NewTune ,
line = 397 tune to freq 12575000, symbol rate 0, pls no 0 blind tp 0, 12574042, 6000 blind scan
freq = 12574042,
symbol rate = 6000000
file= nim.c,lock
Search_Mode.Mode=1
Search_Mode.FTAOnly=0
Search_Mode.TVRadio=0
Preset_Mode =0
i=45
Search_Mode.CurrTpIndex=2010
SatData.SatName=Eutelsat 16A_Ku,SatData.uLnbFreqType=5,SatData.uDiSEqC_1_0=0
GetSatMotorAngleToMove : Sat Logitude = 1600
Usals : iAngle(1600), iReceiver_Position_Longitude(1970)
Usals : OK[400]
GetSatMotorAngleToMove : Usals iAngleToMove:400
n32OffsetAngle=400 0xd0 0x40
file = tuner/tuner_interface.c, line = 320
fun = TUNER_SAT_NewTune , line = 397
release key 0x09F61AE5
[TUNER]: try to get N
[TUNER]: try to set N 0, time = 101784790
[INSTALL]: update tp [2010] [0] [0]
[DEMUX]: disconnect demuxid[0]
CurrSatIndex = 55, NextSatIndex = 255, CurrTpIndex = 2010, NextTpIndex = 65535
scan failed
file= nim.c,unlock
enter finish info 1
enter finish info 1
enter finish info 2
statuse init done !
Alles anzeigen
Tomek22 thanks for your sincere response.Sky Radio TNZ and Veronica TNZ at playback on VLC player have no tons,and unlike when recording content, the footage is correctly reproduced in Windows Media Player.This applies to CrezyScan and IQMonitor.
As far as this frequency is concerned, there is a signal variation in me the level is constant at 63% while the quality varies from 30% to 100%,in dB with 15dB falling to 3dB,but I guess it's close to Radio 10 TNZ, Radio 538 TNZ.
I have now discovered that this is the frequency of the feed
I´m late, I know...
Just my manual scan here - probably I forgot one?
/edit: one more...
11069.965 H,274,1/2-Slam! Main-new symbol rate,
11070.351 H,274,1/2-100%NL MAIN-new symbol rate
the only thing I can see from here 11016H1500
1=10803,H,30000,34,2 ;-44 dBm, 0.9 dB; 18:40 10/10/2018 No Locked
2=10886,H,30000,35,2 ;-44 dBm, 0.5 dB; 18:40 10/10/2018 No Locked
3=10976,H,24110,34,2 ;-46 dBm, -0.5 dB; 18:40 10/10/2018 No Locked
4=11002,H,8332,56,2 ;-46 dBm, -0.1 dB; 18:40 10/10/2018 No Locked
5=11016,H,1499,34,1 ;-47 dBm, 4.4 dB; 18:40 10/10/2018
6=11041,H,4166,56,2 ;-49 dBm, 0.4 dB; 18:40 10/10/2018 No Locked
7=11512,V,29950,23,2 ;-55 dBm, 0.4 dB; 18:40 10/10/2018 No Locked
8=11595,V,30000,56,2 ;-55 dBm, -0.9 dB; 18:40 10/10/2018 No Locked
9=12602,H,30000,23,2 ;-52 dBm, 1.2 dB; 18:40 10/10/2018 No Locked
most of them I think from "E16A Sub-Sahara Africa" Listed in FS by Afreaka & Matie Yendu
Yes, I can receive the Sub-Sahara-beam in Agadez, south of you, with 100cm without problems, even if the signal on some tps is not very high (sorry, I have no dB). Interesting, that you have lock on 11016 H (E-Télé).
very good Afreaka
may be the Low SR 1500 which makes the signal locked
I see some thing like that before with NigComSat-1R @ 42.5° East12539H5000
11071.127 H,176,3/4-BNR_AMS(new symbol rate)
11016H SR changed to 2083 .... No locked
